585,599 active members*
3,608 visitors online*
    Feb 2009
    11
    New small cnc router build
    I have been lurking aroumd for over 10 years and finally got the courage (and the cash) to build my own cnc router. It has about a 2 x 2 cut area. It is wood with openbuild v rails and openbuild delrin v wheels. Driven by all thread rods. I wanted to start a build post mostly to ask questions about things i can not find a solid answer to on the forum. I have the machine together and i have been working on the eletronics part and now i am stuck.i am using the Long Motors DM542A and bob.
    I have found a couple of threads about the wiring of this set up and i have attempted to wire the driver up with a common ground and +pul and +dir plugged into pin 2 and pin 3. As well as putting +pul and +dir to +5v and -pul and - dir to pin 2 and pin 3 with no luck. The motor has a thud when the power supply is plugged in. When everything is powered up then the motor ca not be turned by hand. I think i am setting mach3 correctly. Estop is set to active low pin 0, pin 2 & 3 active low, dir low port 1.the motors are 425 oz 4 amp 4 wire steppers. To move i have been just trying the arrow keys. The jumpers are set to 2.78 amp and 1/4 step. With the wire the driver connected with a common ground and +pul and +dir plugged into pin 2 and pin 3 i use a multimeter and check pin 2 and ground and i get a constant 5v dc.
    Please help, electronics are not my thing.
    I have attached a standard picture of the driver and bob i have.
    Thank you for any help.
    Richard
    Feb 2009
    11
    Re: New small cnc router build
    Can anhone please direct me. I have searched and read mulitiple post on this as well as watching allt of youtube videos. I clearly understand all the various ways of wiring this setup as well as setting mach3 but i am still having the same problem please help
    Sent from my LG-H631 using Tapatalk
    Jog back and forth, and measure in each direction. It should be 0V in one direction, and 5V in the other direction. If it's not changing, then chances are that your port address is wrong.
    Also, are you using a 32 bit Operating system? If you're using a 64 bit OS, then the parallel port will not work in Mach3.
    Feb 2009
    11
    That answered it. It is a 64 bit windows 7. I have linux cnc instakled on dual boot so i will try to go that route. Thank you. I can stop banging my head now
  1. Newb build, Small home MDF cnc router
    By Brieg in forum DIY CNC Router Table Machines
    Last Post: 12-29-2013, 12:35 AM
  2. Build Thread: Kflop with small cnc router
    By gavztheouch in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-24-2013, 05:15 PM
  3. small desktop router build idea
    By ma1 in forum DIY CNC Router Table Machines
    Last Post: 03-04-2011, 08:50 PM
  4. build/buy cnc router for small rc parts
    By lokiwizz in forum DIY CNC Router Table Machines
    Last Post: 02-13-2009, 02:34 PM
  5. Need some good suggestions on a small cnc router build.
    By natlight in forum Open Source CNC Machine Designs
    Last Post: 01-09-2009, 02:42 AM
