586,000 active members*
4,834 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Gibbs2012+w/Advanced CS and Fadal VMC40+VH65 Rotary Post Problem
    Dec 2007
    11
    Hello, I learned enough to get a good CPR for my first Gibbs part which requires 4 simple rotary positions for machining. I used the posthaste with "Fadal Format 1 (E), 4ax simult (InvTime),pM4 selected and get the message "Warning: This version of the post does not support rotary motion." I am programming with rotary positions only, not simultaneous moves since I have ACS and not rotary milling. Anyone have a post for this VMC40/VH65 combination or a better posthaste file to work with on the plugin. Is there a position only 4th axis posthaste file for ACS I should be getting?
    Mar 2006
    158
    Re: Gibbs2012+w/Advanced CS and Fadal VMC40+VH65 Rotary Post Problem
    The first question would be, did it actually post the code correctly?
    It may just be informational.
    Otherwise, give the boys at Posthaste a call.
    I played with it a little a few years back, and they were very helpful.
    Lastly, the best way is to but the correct GibbsCAM post from your authorized reseller.
    Then you will get exactly the code you need.
    Dec 2007
    11
    It wouldn't do anything past the warning-- the only option to get past the screen was abort. The posthast for the 3 axis puts out code all normal however. Since I am not on maintenance-- would they actually sell me a post?
    Jul 2011
    14
    Send me your e-mail.
  1. How to change seals on VH65 rotary
    By Andy Fritz in forum Fadal
    Last Post: 08-06-2011, 04:11 AM
  2. Fadal VH65 4th Axis on E-Bay
    By scadvice in forum Fadal
    Last Post: 04-03-2009, 08:50 PM
  3. Fadal VH65 Oil/lubricant 4th Axis Rotary Table
    By victortango in forum Fadal
    Last Post: 07-20-2007, 02:19 PM
  4. WTB Control box for VH65 Rotary Table
    By Fudd in forum Fadal
    Last Post: 07-14-2006, 12:49 PM
  5. Fadal VH65 on eBay
    By Edster in forum Fadal
    Last Post: 06-13-2006, 04:50 PM
