when I render the part it draws it super fast on the screen and I want to slow it down,, there has to be a setting for it but I can`t find it
EZ-CAM's simulation can be controlled under the stock setup using the slider, or you can use 0 thru 9 on your keyboard. 9 would be the fastest speed and 0 steps through using the enter key.
but sometimes 7 is to slow and 8 to fast .
the steps could be better spaced.
greetings bertus
