585,758 active members*
4,608 visitors online*
Results 1 to 8 of 8
    Feb 2010
    36
    --Unlocking Path Pilot--
    Hey There,
    I am interested in purchasing Path Pilot for my 2 Tormach 1100s both running series 3 upgrades and running ar X and Y at 200 IMP and Z at 100. I need to unlock Path Pilot and dial in my motor configurations manually. Tormach has told me NO WAY will we tell you how.
    I am not about to slow my machines down from these setting in Mach 3, but would like the benefits P.P. has. Need to unlock it---HOW?
    Thanks very Much,
    Jim Anderson
    Anderson Prototypes
    Jul 2004
    1424
    Re: --Unlocking Path Pilot--
    Ask TurboStep, he has his machine running at 157 ipm. My impression is that he didn't have to unlock anything, just edit a config file.
    http://www.cnczone.com/forums/tormac...ml#post1751098
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Feb 2010
    36
    Thank-you,
    Was hoping to keep at least 200 IPM, but thats heading in the right direction.
    Always,
    Jim Anderson
    Anderson Prototypes
    Jun 2012
    182
    Isn't PathPilot just LinuxCNC?
    Sep 2009
    1856
    yes 2.7 with tormach front end
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Dec 2013
    267
    Pretty sure there isn't any kind of "unlocking". The entire configuration is sitting behind the ~operator/tmc softlink and can be edited with vi existing on the distro.
    If you don't know what that means, then it's going to be tougher to reconfigure the system, but (once installed) nothing is encrypted / locked / hashed or otherwise.
    Feb 2010
    36
    Ok---I was putting off buying it because I didn't want to slow down the machines from what I can run in Mach 3. I would sure like to hear what improvements anyone has had once they converted.
    Thanks very Much,
    Jim Anderson
    Anderson Prototypes
    Sep 2012
    1543
    I "unlocked mine" by hitting Alt+shift at bootup. Then finding the correct config file.
  1. Path Pilot HAL Extensions
    By Hadane in forum Tormach PathPilot™
    Last Post: 04-25-2020, 07:50 AM
  2. CNC Scanner and Path Pilot
    By RA-Bowtie in forum Tormach PathPilot™
    Last Post: 10-12-2015, 05:31 PM
  3. Subroutines with Path Pilot
    By dbren in forum Tormach PathPilot™
    Last Post: 07-27-2015, 04:31 PM
  4. Path Pilot Sub Routine
    By csm-Guy in forum Tormach PathPilot™
    Last Post: 04-08-2015, 05:23 PM
  5. Welcome to the Path Pilot forum!
    By kstrauss in forum Tormach PathPilot™
    Last Post: 03-13-2015, 01:41 AM
