585,880 active members*
8,015 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 Input issue - Spindle Index Opto Interrupter
    Apr 2004
    20
    I am having issues getting my opto interrupter interfaced to the G540 and Mach3.
    I had no problem with NC limit switches.
    With the opto, I get 5.15V normal and when triggered I get .69V across the signal and ground connections. It is powered from the USB port.
    But, when I connect to the Gecko, I get 8.46V and 2.34V.
    I just don't understand how this happens, I cant get Mach 3 to recognise any triggering.
    I checked wiring in the controller and signal is going to pin 1 on the Gecko and ground goes to Gecko pin 12.
    Would anyone know what I have done wrong???
    Rob, Sydney
    Apr 2004
    20
    Re: G540 Input issue - Spindle Index Opto Interrupter
    All fixed.
    I just used a 12v power supply from an old hub, and it worked perfectly.
    I am sure it is over voltage, but if it dies I have 3 more!
    Rob.
  1. Spindle Encoder Index Issue.
    By Contract_Pilot in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2015, 09:15 PM
  2. G540 and Mach 3 Spindle Index input not working
    By AVRnj in forum Gecko Drives
    Last Post: 02-08-2014, 11:38 PM
  3. Spindle Index Input Erratic.
    By Katoh in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2013, 02:48 PM
  4. Cheap and easy spindle index sensor for G540 and Mach 3
    By grizzlymog in forum Gecko Drives
    Last Post: 06-10-2012, 01:16 AM
  5. Spindle index switch and G540
    By cmanning in forum Gecko Drives
    Last Post: 09-15-2010, 02:46 AM
