585,973 active members*
4,213 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazatrol EIA Dash control Illegal Interupt Error.
Results 1 to 7 of 7
    Sep 2013
    I have a QT-6G. Today I powered up the lathe and set up a new job and everything worked fine, including all axis, servo and control functions. Once I hit the "File Program" function to load a program I received an "illegal interrupt error" and the control locked up solid and I had to cut main power to shut it down. Problem was persistent and I suspected possible garbaged data in program memory. I checked main pcb back-up battery and it was down to 1.2 volts from the normal 3 volts. I logged all parameters and tool data then replaced the battery. Once powered up again I got the "illegal interrupt error" as soon as the control finished booting. I reset the pcb using the reset pins on the pcb thinking that memory may have not been fully cleared during battery change. On power up same problem persists.
    During power up the LEDs on the PCB follow normal sequence and the servos power up for a second at the end of the boot process, then the error appears, both error LEDs light and the servos shut down.
    I know this is a long shot but any help would be appreciated. Especially if someones feels that I was going down the right road with the back-up battery but maybe I didn't clear the PCB memory correctly.
    Gary
    Apr 2006
    111
    Re: Mazatrol EIA Dash control Illegal Interupt Error.
    Quote Originally Posted by cinman View Post
    Gary
    Could you share me the parameter file? thank you very much
    Sep 2017
    139
    Hi cinman
    Could you confirm if the QT6G is with a Mitsubishi M64 controller.
    If yes, at the time of alarm occurrence, what is the status of 7 seg LED on the controller. Also please check if the WDER led is lit red or not.
    The reset pin is just for re-boot, it will not erase the memory
    Jan 2020
    Potrei condividere i parametri di un qt6 Mazak?
    Grazie tante
    Gary
    Bonjour cinman
    Est ce que t'as trouvé une solution pour l'alarme elligal interrupt
    Aug 2023
    Quote Originally Posted by Ennovation View Post
    Bonjour cinman
    I've the same problem with a QT200 (that we've just purchased)
    I need only to change battery ? Or may be parameters have been lost ?
    Thanks in advance
    Regards
    Pierre Erik
    Hello everybody,
    I purchaused a MAZAK QT 6T but it doesn't work due to this error code: ILLEGAL INTERRUPT !! , and with an hexadecimal code.
    I attache picture for this issue. Coul dyou please tell me if some one has find the solutions ?
    Thank you for your help , I will be gratefull !!!
  1. Mazak QT200 EIA DASH Control - Need parameters
    By apsmx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-07-2022, 07:39 PM
  2. Solidcam illegal screenshots in error reports. Maybe a class action lawsuit coming?
    By theinsider00 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-07-2016, 02:43 PM
  3. Error 065 Illegal Command in G71-G73
    By CNCALLthethings in forum Fanuc
    Last Post: 09-30-2011, 02:09 AM
  4. Mazatrol M-2 Error 367
    By ReePMM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-14-2010, 06:39 PM
  5. mazatrol m32 FLD Error
    By M42 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-10-2009, 08:12 AM
