585,760 active members*
3,676 visitors online*
IndustryArena Forum > CAM Software > CamBam > Coolant on/off by CAM style definition
    May 2010
    327
    I've enjoyed using CAMBAM for quite some time now.
    I have a few operations where I do not want coolant to run. I normally open the .nc in an editor and remove the M8 commands after the tool change or beginning of operation as necessary.
    Is there a way to assign coolant OFF to a specific CAM style? I've looked around - but am older and blinder than I used to be.
    Cheers,
    Bill
    Manufacturing & Development
    ThermaeCooling.com
    Dec 2008
    292
    Re: Coolant on/off by CAM style definition
    You could do this by modifying the Post Processor. You will get a more detailed answer if you ask your question on the CamBam forum. Great (and very quick) support there for about any challenge you may come up with using CamBam.
    CamBam - Index
    Don
  1. Replies: 0
    Last Post: 06-27-2014, 07:09 AM
  2. Replies: 7
    Last Post: 06-24-2014, 07:25 AM
  3. Using a Dimensioning Style As a "Default Style"
    By nfrees114 in forum Solidworks
    Last Post: 09-21-2012, 02:37 AM
  4. Autocad Style Sketching vs Constraint Style
    By Beefy in forum Uncategorised CAD Discussion
    Last Post: 08-20-2012, 10:26 PM
  5. Set Up Definition
    By SPEEDRE in forum Bridgeport / Hardinge Mills
    Last Post: 02-22-2008, 02:46 AM
