585,938 active members*
3,682 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Does recalculate work for drill paths?
    Dec 2011
    97
    In 5.0.2015.417, Recalculate toolpath doesn't seem to recalculate a drill path. Should it?
    Dec 2011
    97
    Re: Does recalculate work for drill paths?
    This looks like a bug. Frequently after selecting Recalculate Toolpath, and then selecting a drill path, nothing happens. Selecting a mill path to recalculate always works correctly and after the dialog to recalculate the mill path is closed, it is then possible to go back and recalculate the drill path.
    Dec 2011
    97
    Actually, recalculating mill paths doesn't reliably open the dialog either.
    Apr 2003
    1357
    This was a known issue in the past. Are you sure you are working with the latest service release (14)?
    Dan
    Dec 2011
    97
    I am using 5.0.2015.417
  1. Recalculate Revolution Roughing
    By Jason Forbes in forum MadCAM
    Last Post: 11-22-2014, 09:45 PM
  2. Why does this drill cycle not work
    By blakemachine in forum Milltronics
    Last Post: 08-20-2012, 04:57 AM
  3. Paths
    By APinSoFla in forum Milltronics
    Last Post: 10-04-2010, 09:16 AM
  4. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
