ZW3D 2015 SP has been released!The enhancements of ZW3D 2015 SP focus on the usability, stability, and function extension to provide a better design and fast machining CAD/CAM experience. It is ideal mid-range CAD/CAM software offering powerful CAD/CAM functions at less cost. This version would not fail you if you had high expectations for ZW3D 2015. This thread is mainly about the new CAD features of ZW3D 2015 SP. Below are some CAD highlights that you may be concerned about. Should you have any suggestion, please add your comments on this post.
1. Usability
· New Electrode ribbon tab (Not included in Lite & Std. version)
· Tweaked picking and highlighting
· Improved rotation center detection
· Optimized result display of Interference Check
https://youtu.be/XfDKy7eETrY
2. Stability
· More robust Boolean operation
· Improved Pattern
· Enhanced "Face Offset" & "Direct Edit"
https://youtu.be/wIgtYj2p9hE
3. Function Extension
· Import/Exportpoints and wireframes in Parasolid(excluding sketch
curves)
· Export drawing views as curves/block in DWG/DXF
· Added "Gap" option in "Structure Member" command
· New "Structural BOM" command to read out the attributes of the
structure members, like material, mass and length
https://youtu.be/PEbBYNt5z8Q
4. Other CAD Enhancements
· Sketch: Show up the center point of the circle and arc by default
· Stock command supports STL objects
· New "Gap Tighten" command
· More commands support external thread
