The use of this element increases the ability of the fibers that conduct light-emitting diodes, which are then pumped through the fibers to the optical heads. At that point, the beam of light Expands that create the laser marking capability. The beam of light then marks the material using one of four methods:
engraving machine
Ablation or removal of a layer of the material
Carbon migration or etching of the surface of the material to change the color Bonding
You can use fiber laser marking on a wide range of materials, from different types of metal through to leather and plastics. That types of metals lend themselves well to fiber laser engraving include platinum, stainless steel, silver, gold and bronze. Carbide, tungsten, copper, aluminum or medical-grade alloys also RESPOND well to fiber laser marking.
Ways to Use laser engraving machine Marking
Fiber laser marking, Which is also known as cnc engraving machine because of the Resulting surface pattern produced by the ablation process, is used for a variety of applications Including:
Medical Devices and Equipment - surgical devices and other medical products require frequent sterilization That (often at high temperatures) use identification marks That can withstand the cleansing process without interfering with the health of the patient.
Jewelry Engraving - creation of unique marks or brand is IDENTIFY items of jewelry has become popular for copyright protection and recovery of stolen property. The precision of laser engraving is also used to personalize pieces dry as wedding bands with the vows or the couple's marriage date.
Laser Cutting - light laser cutting is also very popular in the jewelry industry. Light metals are used to create name cutouts and monograms as well as other design cut outs.
Computerized parts dry as printed circuit boards use laser marking to produce clear, high-resolution images That are ink- and acid-free for use in electronic applications.
If you're in the business of manufacturing or selling any of These types of products, then fiber laser marking equipment is the one you need. This is just a small sampling of the many applications of fiber laser That markers are being used for.
Advantages of Fiber Laser Marking
machineFiber fiber laser marking laser marking technology has a number of advantages With over other types of laser marking systems. The equipment is simpler and cheaper to use than other forms, due in part to the minimal maintenance required and the elimination of any consumables. There are a range of different types of laser marking and engraving machines available, Including:
Fiber (Ytterbaum) 1070 nm
CO2 (gas laser)
Nd: YAG Flash Lamp (solid state)
Nd: YAG Diode Pumped
Vanadate (Nd: YVO4)
One of the benefits of using fiber markers is minimal replacement part - the diodes have a lifespan significant_coeff_flag so there's no need to budget extensively for parts. When they need replacement, it can be done in the field without Requiring a qualified technician perform it any laser alignment.
Then there's the convenience. The air-cooled design is more convenient than models That use water for cooling purposes, and the quality of the laser beam is better than most of the other types of laser marking machines available. And in terms of space Requirements, the equipment has an exceptionally small footprint, Which Means you can place it in almost any location and operate it without using precious space. This makes it much easier it integrate into an assembly line, or a small factory or workshop without reconfiguring your entire production facility. Overall, fiber laser marking technology is vastly more convenient and cost-effective than other types of marking and engraving machines.
