585,894 active members*
4,131 visitors online*
Results 1 to 6 of 6
    Aug 2014
    11
    Cut is not accurate - is this Mach 3 issue?
    I was cutting a sign out today and about 3/4 the way through cutting the sign the x axis went long by almost an 1 inch. Is this a mach 3 problem or something else.
    I am getting a clicking noise in my x axis motor. Its a nema 23 and I am using a Gecko control panel. The cnc router is homemade.
    thanks
    Apr 2004
    475
    Re: Cut is not accurate - is this Mach 3 issue?
    I don't use Mach, but I doubt that was the problem. However, steppers won't jump an inch on their own so 2 ideas past Mach,
    1) stepper stalled in one direction and moved correct distance back, seeming to move further back than it should have but really die to a stall.
    2) electrical noise that put (a lot) of extra step signals to the driver.
    My guess is number 1.
    Is the axis 1 or 2 motor and how is it driven, motors, bearing etc?
    Apr 2013
    1899
    I doubt it's a Mach3 problem. Mach3 has been around for quite a while and I think it is a very reliable software. I have been using it for a while now, but the only times I had issues when I was trying to configure it. Set too high speed for my CNC and had some motor stalling issues. Apart from that, I had problems with my driver earlier, before replacing that crappy, 3 axis Toshiba 6560 based driver with much better ones, but not even with that infamous blue card had I that much of an accuracy issue as you are talking about. Look at your configuration is my best guess. Mach3 bug would be my last guess.
    Questions: are you sure your G code is right? Is the problem repeatable or random?
    Jun 2004
    6618
    Check all of the couplers. A loose set screw can cause this.
    Lee
    Jan 2016
    19
    I am getting the same problem on my x axis. It's running fine and then moves out of step about an inch and I hear the clicking noise in the motor also. Did you figure out the problem?
    thanks[/QUOTE]
    Nov 2013
    4370
    That's the stepper losing steps. The cutting forces and/or acceleration exceed the motors torque (at the speed and operating voltage) and consequently it loses steps.
    Repeat the experiment but WITHOUT the tool in the spindle. Does the fault recur? If not then that demonstrates that the cutting force is causing the motor to overload.
    Craig
  1. Mach issue
    By keithmcelhinney in forum Novakon
    Last Post: 02-12-2019, 03:41 PM
  2. Mach 3 Spindle Issue
    By thatotherguy in forum Machines running Mach Software
    Last Post: 08-15-2013, 09:39 PM
  3. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  4. MACH 3 FREEZE ISSUE XP pro 02
    By carbidecraters in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2010, 07:49 PM
  5. Mach issue with my mill
    By Rich05 in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2008, 12:00 AM
