Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
Description
I am selling this Emco Compact 5 CNC automatic tool changer. It was pulled from a working unit and fully tested.
The mounting bolts ARE NOT included.
It can hold up to 6 tools.
It comes with 2 carbide inserts holders
It is in good condition and working perfectly.
It has some cosmetic flaws in the paint and some oil and oxydation stains.
Perfect for homemade lathes or retrofit.
If you're buying this for a homemade lathe, you will need a 12 VDC regulated power supply to make it run.
The polarity determines whether the tool holder is turning or in locked position.
List Date: 2/8/2015
For more info, click here to view the original listing: Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
This item is no longer available.
Mobile friendly version: Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
Go Mobile: Download the free Panjo iOS app now!
