DynaMechtronics DM4800 w/Rotary Table
1994 Dyna Mechtronics DM4800 VMC w/Rotary Table
- 32in X Travel
- 20in Y Travel
- 20in Z Travel
- 15/12 HP Spindle
- CAT40 Taper
- 0-6000 RPM
- Auto Lubrication
- Auto Coolant
- 11,400lb machine weight
- Box Way (Z Axis)
- Linear Guides (X & Y Axis)
- Mitsubishi Meldas 520M Control
- Calmotion USB adapter installed
The Good:
- Holds excellent tolerance (0.001")
- Spindle is in good shape
- Coolant system functions flawless
- USB adapter included for easy program transfer
- All Axis traverse smooth, and quickly
The Bad:
- The tool changer has not worked properly for a long time. A previous owner crashed it. Could be fixed, but was never needed.
- Light surface rust on way covers and bed (it's 20 years old), no damage
- The Z axis could use a new lube wiper, it does leak a little extra way oil
- The reason it's for sale: Needs a new PSU, and electronic spindle drive. A Mitsubishi service tech has looked over the machine and determined a power issue arose which took out both items. The part numbers are QX084 & MDS-B-CV-110.
Included:
- All manuals (Programming, Service, Control)
- Zebra Coalescer to skim tramp oil
- (6) CAT40 pull studs for spindle
- Golden Sun CNC-201R Rotary table
- 200mm diamter
- Vertical/Horizontal mountable
- Max Load: Horz. 200Kg/ Vert. 100kg
- Min Increment: 0.001 Deg.
- Max 22rpm
** BUYER IS RESPONSIBLE FOR RIGGING AND TRANSPORTATION OF THE MACHINE
List Date: 3/26/2015
For more info, click here to view the original listing: DynaMechtronics DM4800 w/Rotary Table
This item is no longer available.
Mobile friendly version: DynaMechtronics DM4800 w/Rotary Table
Go Mobile: Download the free Panjo iOS app now!
