585,589 active members*
2,752 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > ExcelCut 4 Axis Wing Cutter with Source Code
Page 1 of 2 12
Results 1 to 20 of 40
    arman Guest
    Hi all,
    For those who interested pls visit http://www.excelcut.netmyne.com .
    Cheers,
    arman
    Feb 2005
    15
    Any plans to support DXF file format ?
    Looks great !!
    Tal
    Looks nice.
    ¿Where can I find plans for a foam cutter?
    Hugo Carradini
    Feb 2005
    15
    plans for foam cutter
    Quote Originally Posted by tbarnea View Post
    That was nice.
    Thanks.
    Hugo Carradini
    arman Guest
    hi tbarnea,
    i like to have dxf input but not so soon. busy with other thing...
    thanks for your suggestion.
    arman
    May 2005
    Very interesting indeed.
    Very well illustrated and described.
    Thank you for the information.
    arman Guest
    Hi all,
    excelcut new feature:
    1. accept dxf file
    2. support independence x, y step/mm
    Cheers,
    arman
    Jun 2004
    33
    Quote Originally Posted by arman View Post
    Hi all,
    Cheers,
    arman
    downloads don't work arman why?
    arman Guest
    hi cwilliam,
    i did some changes to the file. should be ok now !
    new improvement:
    1. implement with "add & subtract" algorithm - more accurate & fast
    2. Backlash compensation added
    rgds,
    arman
    Sep 2003
    1113
    First reference to ExcelMill does not link - oh the trials of website building - eh? Downloads ok from second NOTE: first ref is minus "www" dubdubdub... second works
    Sorry I missed a chance to meet you when I was in JB. Maybe next time.
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Sep 2003
    1113
    ARMAN - just a quick question or 2...
    1. Any plans to port it over to Open Office 2.0+ ? I messed around a bit with OO and it does not function a clearly or easily as I had hoped - maybe I go get some excel...
    2. Could you share some more pics and plans/details of your nice looking foam cutter? There are always guys looking for ideas like yours. Its your thread or start another I guess.
    :cheers: Jim
    arman Guest
    hi highseas,
    thanks for your info about the "excelmill" broken link.
    are u flying in jb ?
    about openoffice, i've not yet play around with it. the reason i use excel 2003 to create my software is because my wife is a teacher. as a teacher she get school computer and has excel 2003 installed. so when she's not using during the night i'll take incharge.
    regarding my foam cutter machine, it's rather ugly actually. i'll consider to post some picture on my website.
    rgds,
    arman
    May 2007
    42
    hi arman
    I'm having some problems with the software -- like it works some time and it doesn't other times I'm running it on excel-2007 and i think I'm having an I/O problem -- like the software is not taking the port address or something like that !
    what should i do please advice
    thanks for your time
    sahil
    arman Guest
    hi sahil,
    i don't have excel 2007 to test. may be your pc speed is too fast. try increase speed delay from 10000 to 20000. pls let me know if this help.
    Sep 2003
    1113
    arman - Greetings.
    Porting the ExcelCut to Open Office would be real nice! Aa great combo - 2 freebie programs!
    Is there a way to test/check a file without having the controllers attached to the pc? I'd like to do that to make sure all is well before taking the file out to the "shop." Maybe some trick to fool the software into not looking for the controller?
    :cheers: Jim
    May 2007
    42
    hello arman
    i think i have not made my question clear! what i meant was--- i was having a start up problem i.e once i open the program ( for the 1st time ) i input the parallel port address and un-check the home limit option the save the file and then give power to the machine wala it works -----as far as delay speed is concerned i have gone as low as 2000 without any glitching problems .
    now for the problem , at the time of closing the program i get an saving option ( if i save the current setting are not ) once the program is closed and opened back it won't work ! but all of sudden after lots of opening and closing is works !
    I'm new to all this stuff ! and i have been running this program on IBM laptop P4 , OS-XP service pack 2 and office 2007 !
    thanks again for the help and i think its an wounder full program,i just have to work out my bugs
    sahil
    arman Guest
    hi sahil,
    try save as 2003 version. i'll test it with 2007 next week. (Holiday season in Malaysia)
    hi high seas,
    you can do that by
    1. on 'limit switch' section UNCHECKED the Enable Home & limit Switch
    2. on 'Shape Cut' section put 'Pause on Cut' = 1
    rgds,
    arman
    May 2007
    42
    hi sahil,
    okay i will do that n have a happy holiday season
    bye
    sahil
    May 2004
    10
    I lost my copy of Excelcut 4.2 due to pc failure. I don't have a backup, web site is MIA, and I can't get a hold of Arman. Can some one seed me a copy to [email protected]. I have a password to unlock the source so I good there.
    Regards,
    Bart
Page 1 of 2 12
  1. 4 Axis CNC - MS Excel Source code (VBA)
    By arman in forum Visual Basic
    Last Post: 03-06-2018, 01:37 AM
  2. Wing cutter in the Netherlands
    By Witsenburg in forum CNC Wire Foam Cutter Machines
    Last Post: 10-16-2011, 01:11 AM
  3. Wing cutting and 4 axis g-code
    By THend in forum CNC Wire Foam Cutter Machines
    Last Post: 07-08-2009, 11:24 AM
  4. G-Code viewing source code
    By Hussam in forum Visual Basic
    Last Post: 03-15-2009, 06:15 PM
  5. CNC Foam cutter for RC plan wing
    By jc de campo in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2008, 01:21 PM
