585,743 active members*
5,136 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Powermax 45 Fine Cut Consumables Question
Results 1 to 11 of 11
    Nov 2003
    55
    Jim (or anyone)
    Are there fine cut kits available for the powermax 45 machine torch? I can't seem to find them on any of the sites that I have bought Hypertherm consumables from.
    If s, do you have part numbers?
    thanks
    µ
    Nov 2014
    34
    Re: Powermax 45 Fine Cut Consumables Question
    Use 30A consumables
    Jan 2008
    2247
    There are no Finecut consumables for the Powermax45. For similar results use the T30 (30 amp consumables) parts as listed in the cut chart section of the Powermax45 operators manual.
    Jim Colt Hypertherm
Name:	30amp consumables.png
ID:	294206Click image for larger version.
Name:	30ampcut chart.png
    Quote Originally Posted by microdot View Post
    Jim (or anyone)
    thanks
    µ
    Feb 2016
    7
    Will you only be able to use those finecut consumables up to 30 A ?
    Sent from my SM-N920C using Tapatalk
    Jan 2008
    2247
    As previously mentioned...there are no "FineCut" consumables for the Hypertherm Powermax45. Fine cut consumables are available for use with the Powermax65, 85 and 105 systems.
    There are 30 amp non-shielded consumables that will produce similar results (as the FineCut), and have a maximum rated amperage of 30 amps. See the cut chart on my previous post. If you choose to operate these 30 amp rated consumables at an amperage higher than 30 amps....expect rapid nozzle orifice wear and deteriation of cut quality as a result.
    Jim Colt Hypertherm
    Quote Originally Posted by MXDURO View Post
    Feb 2016
    7
    Thanks for the reply Jim, have done a few test and will keep with the standard 45 A consumables.
    What settings do you recommend for 14 gauge / 2mm mild steel with the std consumables keeping the speed below 150 ipm / 3810 mm/min ?
    Jan 2008
    2247
    I would use the 45 amp shielded consumables for the 14 gauge, set amperage to 30 .....set pierce height to .1", set cut height to .06" (adjust arc voltage to maintain this height during steady state cut), set cut speed to about 130 ipm. This should be close.....though you may need to go a bit faster to eliminate heavy dross.....depending on the chemistry of the steel.
    Jim Colt Hypertherm
    Feb 2016
    7
    Thank you for the info Jim, will test and compare.
    Regards,
    Geo
    Feb 2016
    7
    Thanks Jim, i used your settings last night and it does a very nice job just had to crank up the speed to around 157 ipm / 4000 mm/min to almost eliminate the dross.
    Regards,
    GeoAttachment 317424
    Feb 2013
    51
    Jim, I noticed these aren't book settings for 14 gauge using 45A consumables. Does cutting at a lower amp and slower speed lead to longer consumable life?
    Quote Originally Posted by jimcolt View Post
    Jim Colt Hypertherm
    Apr 2015
    12
    Regards,
    Geo
    where can i get this awesome screen set
  1. Where to buy consumables for Powermax 125
    By cory1504 in forum Hypertherm Plasma
    Last Post: 10-15-2014, 04:21 AM
  2. Question about Fine-cut consumables
    By vacextar in forum Hypertherm Plasma
    Last Post: 05-28-2011, 12:01 AM
  3. Fine Cut consumables and Aluminum
    By Largemouthlou in forum Hypertherm Plasma
    Last Post: 11-29-2010, 03:03 AM
  4. kerf width using fine cut consumables
    By patriot customs in forum Waterjet General Topics
    Last Post: 05-17-2010, 05:36 PM
  5. Thermal Dynamics Fine Cut Consumables?
    By tof1 in forum Waterjet General Topics
    Last Post: 04-10-2009, 01:13 PM
