I just bought 50W laser from eBay.
The first problem is when I power it up, it's not aligning well at the origin. The X axle is going slowly to the right for about 5 min. and its stops somewhere on the middle of the plate.... this if it starts from the upper-left corner. If the position before start up is more to the right, then it goes up to the righter limit and it's bumping up in the metal bar. I would say that it moves around 20 cm on the X axle util it "finds" the origin
The second problem is with the rotatory accessory. After connecting it, if I move the Y axle from the control panel, it rotates. It does nothing moving the U or Z axles from the panel. If I send a job from the PC it's moving only the X axle, no matter if checking the enable rotation or not from the software.
PLEASE, could you help me?
I apologize for my bad English... I'm not a native speaker.
