Originally Posted by
SCzEngrgGroup
You can step by ANY amount the hardware is capable of. On Novakon machines, this is 0.0001". If you think you can only step by 0.010", then you have a lot to learn about using Mach3. The accuracy of an edge finder is determined first and foremost by how you use it, and then by the physical accuracy of the device itself. The Tormach electronic edge finders I use are good for a few tenths (and even that can be virtually eliminated by using it properly), which is well below the accuracy of the machine as a whole.
Regards,
Ray L.
