585,758 active members*
4,562 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Can't add machining tabs in Fusion 360
    Oct 2015
    Red face Can't add machining tabs in Fusion 360
    Hey guys!
    Brand new to CNC here. My first project is a blade from a video game I play. I want to cut it out using my schools cnc mill, but I can't seem to set up the program right. On of the biggest issues is that I can't seem to add tabs to keep the material in place until the process is complete. Fusion 360 doesn't seem to have a way of doing this.
    Here is my project file: https://www.dropbox.com/s/pth68av1ff...20v10.igs?dl=0
    I would be great if somebody could take a look and see what I am doing wrong. I am milling this out of 440c stainless steel from Jantz supply: CF558 440C Stainless 1/8" (.135"/.149") x 2" x 18" Mill Finish
    The machine I am using is a Tormach 1100 series 3.
    Any and all help would be much appreciated.
    Thank you so much,
    Arland
    Jan 2013
    630
    Re: Can't add machining tabs in Fusion 360
    2D contour -> Geometry -> Tabs. Right where you'd expect it to be.
  1. Tabs
    By wxgeek in forum BobCad-Cam
    Last Post: 07-16-2015, 06:51 PM
  2. Tabs - Hey, I got this
    By KSky in forum BobCad-Cam
    Last Post: 02-23-2015, 01:23 PM
  3. Tabs - Again
    By Magnum164 in forum SprutCAM
    Last Post: 02-21-2011, 03:50 AM
  4. Tabs How and Where?
    By Mr.Chips in forum Uncategorised CAM Discussion
    Last Post: 03-04-2008, 03:08 PM
  5. Tabs in V9
    By MikeA in forum Mastercam
    Last Post: 03-21-2004, 12:55 AM
