585,975 active members*
4,496 visitors online*
IndustryArena Forum > CAM Software > CamBam > Help me get better in the CNC world Thanks
    Jul 2015
    8
    Hi
    I have a small 3040 cnc machine , and use Cambam and Mach 3.
    I can make my G code from DXF files using CAMBAM and load them onto Mach 3 no problem.. They work fine
    Can someone tell me how I can predict where to put my material on my router bed.
    I'm having to do a dummy run to see where the cutter will travel so I know where to place my material.
    I bet its a simple answer so please dont laugh, I am trying hard .
    Thank YOu for your time
    Jul 2007
    1602
    Re: Help me get better in the CNC world Thanks
    Are you setting your origin in CamBam? CamBam 0.9.8 documentation - CAM Part
    Once you have done that, you also need to select where you want the origin to be on your router table and zero the DROs.
    This should be enough to get you started.
    bob
    Jul 2015
    8
    Thanks Bob
    I think I'm almost there .
    WOuld it be better if I represented my material size on my original drawing, and then convert it to a DXF with my work located within the material confines, Then after importing it to Cambam put my machining origin at the say bottom left of my material Rectangle onthe Cambam screen, set up my operations (without including the material "rectangle" in any operations ,Then generate my gcode.
    Then would I put my material on my router bed and set the router table origin to the bottom left corner of my material zeroing the xy coordinates in Mach 3
    Thanks Robbie
    Jul 2015
    Yes, that's exactly how you would do it. Draw your stock having the 0,0 on say the lower left corner. Then zero your machine where ever your drawing zero is.
  1. Hello World
    By Archon117 in forum Community Club House
    Last Post: 07-22-2013, 05:43 PM
  2. New the the CNC world
    By dantyler34 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-17-2011, 01:51 AM
  3. Hello World
    By HeathRiley in forum Community Club House
    Last Post: 10-16-2007, 03:00 AM
