585,982 active members*
4,440 visitors online*
Results 1 to 8 of 8
    Oct 2015
    7
    Need Help for USB plugin for Mach3
    Hi
    I need help to start with mach3. I want to create USB plugin for mach3. I have downloaded the SDK and build the code with Visual Studio 2010. But i got the following error.
    Code:
    1>c:\cnc\mach3development\sdk.2.62\machincludes\mach4view.h(18): error C3500: invalid ProgID 'ShockwaveFlash.ShockwaveFlash'
    1>c:\cnc\mach3development\sdk.2.62\machincludes\mach4view.h(18): fatal error C1103: fatal error importing progid: 'ShockwaveFlash.ShockwaveFlash'
    1>  MachDevice.cpp
    error is pointing in Mach4view.h and line is following.
    Code:
    #import  "PROGID:ShockwaveFlash.ShockwaveFlash" no_namespace raw_interfaces_only
    So how to clear this error.
    I am compiling Blank pluigin from SDK.
    Here i ahve attached Mach4view.h file.
    Re: Need Help for USB plugin for Mach3
    There aren't many people familiar with writing Mach3 plugins.
    I believe that you need to use VS2003, so that may be part of the problem.
    Oct 2015
    7
    yes may be.
    what is prerequisites for this?
    i have extract SDK.2.62 in C drive. And browse the code in Visual studio. is there anything we need to install?
    Oct 2015
    7
    I searched for Visual studio 2003, it is very difficult to get it now.
    and also i think it is not matter of visual studio versions.
    I think there may be mismatch i did or something else.
    Pleas help to get out of this.
    As I said, there are very few people with experience writing Mach3 plugins.
    Geez, I'm sure I have VS2003 (or at least still have the media).
    I also have VS2005 & VS2008 which I still use.
    Nowadays you need to download DDK
    https://www.microsoft.com/en-us/down....aspx?id=11800
    Now to hunt up this Mach3 "Plugin SDK"!
    Nov 2013
    4372
    why? All development on Mach3 ceased six-seven years ago. Whatever bugs and shortcomings it has it will be tuck with.
    If you are going to go to all the trouble of writing a plugin then write it for Mach4. Firstly you'll be able to use a much later version of VS and
    you'll get assistance from NFS provided you sign a Non Disclosure Agreement..
    Craig
    Jan 2018
    1516
    Craig
    You know what many people are like.
    We stick with what we know, lol.
  1. Mach3 Plugin for Ethernet Smoothstepper
    By dwilson26 in forum SmoothStepper Motion Control
    Last Post: 01-31-2012, 07:35 PM
  2. CAM plugin or LazyCAM (MACH3)
    By stevenlgts in forum Uncategorised CAM Discussion
    Last Post: 12-05-2010, 05:36 PM
  3. Mach3 Engraver Plugin
    By bdring in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-06-2009, 12:30 PM
  4. Need help to install plugin to Mach3...
    By jaru-eri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-28-2009, 05:46 PM
  5. Mach3 Plugin Licensing System
    By jemmyell in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2009, 05:20 PM
