585,759 active members*
3,910 visitors online*
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    Feb 2011
    54
    Re: 5-axis for machining metals
    Hey Kenny
    I have asked them based on your suggestion, but their controler does not support linuxcnc.
    Here are some photos of work done today
    Attachment 335696Attachment 335698Attachment 335700
  2. #42
    Feb 2011
    54
    Hey there fellas
    Machine is doing great, and I most fascinated with the accuracy and reliability. Position accuracy and positioning is lower than 0.01 on 150 mm, and around 0.02 on 550 mm.
    I am still working on touch probe system, but that will be a cool feature to have.
    Soon more photos.
    Here are some short videos of machining aluminium 7075-T651
    https://youtu.be/T7AmxaVhgww
    https://youtu.be/SjUm-PSXiBo
    https://youtu.be/C8K9E2Nn2yE
  3. #43
    May 2015
    34
    Thank you for sharing this with us, looks excellent!
    Third video, what is your feedrate for finishing compared to roughing, and spindle rpm?
    Thanks!
  4. #44
    Feb 2011
    54
    Hey there Zeky,
    Thank you for your kind words . Feedrate milling is 1300mm/s @5000 rpm, and finish is 500mm/s @5000rpm.
    Here I will show you the process of making a JIG for my parts:
    1st of all, design of the JIG:
    First picture is the design of the top side. This JIG is designed for full process of making 104 BCD bicycle parts.
    Second picture is much more interesting, as it shows the design fixture, both on fixture table and on JIG.
    Attachment 341754
    Attachment 341756
    To produce this kind of JIG, I had to process the the bottom side. On bottoms side, extrusions had to be machined, which fit perfectly on the slots in the fixture tables.
    Attachment 341758
    Attachment 341760
    The holes had to be milled first. They will be used to fixture the JIG to desired position, before putting adaptive machining to use.
    Attachment 341762
    The bottoms side is done, and ready to flip i over.
    Attachment 341764
    On this picture you can see the design of fixture positions that can this JIG fit. It can fit in 4 positions, on each side on the fixture table. This is my design, and I really love it, as its simple to use and very accurate.
    Attachment 341766
    Adaptive clearing in HSM is a thing of beauty. machining time was 55 minutes, with 4 mm DoC, 1300mm/s, stepover 2mm. End bit was Iscar 3 flute for aluminium. Machining was dry.
    Attachment 341768
    Almost finished JIG, only few holes missing.
    Cheers,
    Marko
Page 3 of 3 123
  1. Replies: 1
    Last Post: 03-09-2014, 01:36 AM
  2. Replies: 0
    Last Post: 10-24-2013, 04:49 PM
  3. Flow 5 Axis Machining on X-Axis
    By pvmachine in forum Mastercam
    Last Post: 09-20-2012, 08:29 AM
  4. 5-axis vs 3-axis machining rigidity
    By Gabe Newell in forum MetalWork Discussion
    Last Post: 03-15-2011, 04:54 PM
  5. New to machining metals
    By Joe Rodney in forum Work Fixtures / Hold-Down Solutions
    Last Post: 07-24-2008, 04:55 PM
