Posted this over in the General Discussion section - and got a big yawn, so I'm hoping you CNC DIY Router table guys can help me out... Thanks!
Hi Everyone - relatively new to CNC, but not new to Mechanical Projects (Mechanical Engineer).
I need to build a 4ft by 8ft X&Y CNC driven table to test very large capacitive touch sensors - (Think about your new 84" TV with a giant iPad touch screen on it, and you'll be close to our product.)
I've seen some 4 x 8 router table CNC set-ups that look like they might be "adaptable" to what I need to do. The table will need to locate a "iPad stylus" within 0.2mm if possible - then gently drop the stylus down to the glass sensor surface - simulating a touch to the screen. Would like to "draw" lines on the sensor if possible (Stylus down then move). So obviously I need maybe 20mm of Z stylus travel as well as X & Y.
Is there anything out on the market that could be adapted for this purpose? Don't need hardly any force as I'm just moving a small stylus. Speed and accuracy are going to be more important - and the motor drive system needs to be as electrically quiet as possible. A bunch of EMI from the motors will screen up my touch sensor.
Does anyone have any ideas on where to get started? Would like to build it ourselves if possible. Driving the table with a Windows PC is preferable. Total budget: 3 to 5K USD for the table & drive system, not including the windows PC to drive it.
All help appreciated - in advance !
Jim
