Hy, can i use "and" , "or" operators ?
someone has a full list of operators of "IF" function ?
also, a list of available comands, as "IF", "While" ?
kindly ! za kitten )
Here is document
AND format example:
IF [[[V181 EQ 1] AND [PP EQ 2]] EQ 1]NHOME
OR could be used in place of AND in this example.
Best regards,
hello again, please i don't understand something in your example :
IF [[[true] AND [false]] EQ 1]NHOME // supose conditions are true and false
IF [[false] EQ 1]NHOME // how does this work ? [false eq 1] ?
and what means NHOME ?
kindly !
hello mr. Wizard nice to hear from you again
i am missing something :
v1=1
IF [[v1 eq 2] eq 1] = IF [ false eq 1] // i dont undersand how can "false" be compared with "1" ?
This comparation is between a boolean (or logical) expresion with a numeric expresion.
IF [ false eq 1] GOTO N100 >>> false=1 and will go to N100, or false<>1, and will skip to next line ?
or is it "false=0" and "true=1" ?
and another thing, about NHOME ... until now i used only numerical adreses, N100, etc, but NHOME is more human ... please, is there a condition for this adresses, like Nxxx, all begin with N, and word should be 7caracters long, and xxxx can be letter or number ? something like that ? ...
For example, i would like to code like this :
drill14 call OS01
drill6 call OS02
reamer call OS03
but i think i can not, so can i use this :
Ndrill14 call OS01
Ndrill6 call OS02
Nreamer call OS03 ?
kindly
This is taken from a programming manual,
format is Nxxxxx ......x can be any number or letter only, maximum of 5 characters after the N
some programmers use NA1 or NB1
where this "label" style may be used to indicate an A or B turret restart line on a lathe
Code:Sequence Name All blocks in a program are assigned a sequence name that begins with address character “N” followed by an alphanumeric sequence. Functions such as a sequence search function, a sequence stop function and a branching function can be used for blocks assigned a sequence name. A sequence name that contains only alphabetic characters is called a sequence label and the one that contains only numbers is called a sequence number. In this manual, both of them are referred to as a sequence name. Sequence Name Designation • Enter letters of the alphabet (A to Z) or numbers (0 to 9) following address character “N”. • Up to five characters can be entered in succession to the address. • Both alphabetic characters and numbers may be used in a sequence name. If an alphabetic character is used in a sequence name, however, the sequence name must begin with an alphabetic character. • Although a sequence name must be specified at the beginning of a block, an optional block skip code may be placed before a sequence name. • Sequence numbers may be specified in any order. • Since sequence names are handled in units of characters, the following names are judged to be different sequence names. • N0123 and N123 • N00 and N0 • When a sequence label is used, place a space or a tab after the sequence label
Superman is spot on with the rules. Where you are having trouble or not understanding is how the AND statement is being used. If you look at the example:
IF TRUE AND TRUE EQ TRUE NHOME
A normal IF statement would be:
IF [V1 EQ 1]NJMP1
IF TRUE NJMP1
If either example is FALSE then the next line will be executed in stead of the jump.
Hope this helps to clarify.
Best regards,
Yes,
But I'm not sure you are getting it yet. Because we are checking a variable we can either check to see of the variable is true or false depending on what we are checking.
IF [V1 EQ 1]NJMP1 = IF variable #1 is = 1 goto line NJMP1, if it is not = 1 goto the next line
IF [V1 EQ 0]NJMP2 = IF variable #1 is = 0 goto line NJMP2, if it is not = 0 goto the next line
IF [V1 EQ 128]NJMP3 = IF variable #1 is = 128 goto line NJMP3 if it is not = 128 goto the next line
Now we can change the logic by changing the criteria;
NE = NOT EQUAL
LE = LESS THAN OR EQUAL
LT = LESS THAN
GT = GREATER THAN
GE = GREATER THAN OR EQUAL
Just about anything you want to accomplish can be done using these logical codes. Perhaps you should tell us what you are trying to do rather than get caught up in boolean logic. We may be able to better help you.
For example, here is a panel switch check routine that is commonly used on a twin turret, twin spindle LT200MY. It is used to verify that the operation panel switched are correct for normal operation of the machine. We can check to make sure coolant is ON, Feed rate override is at 100%, and more as shown. We can even generate our own alarm messages:
G13 (WRITTEN FOR LT200MY WITH P200 CONTROL)
G140
(TURN FEED TO 0 AND SINGLE BLOCK ON FOR RESTART.)
( SWITCHES CAN BE ADJUSTED AFTER CHECK HAS OCCURED.
INDIVIDUAL MODE CAN ONLY BE USED DURING RESTART.)
G50S500
CALL OCHKA (OR OCHK1 FOR NO BARFEED)
G14
G141
G50S500
CALL OCHKB
M2
OCHKA
IF[VORD[0016]EQ 1]NRTS (IF MACHINE LOCK ON)
(IF[VTOFZ[2]EQ 0]NCK0
VUACM[1]='T-A2 NOT AT Z0.0'
VDOUT[992]=1)
NCK0 IF[VORD[0015]EQ 0]NCK1
VUACM[1]='DRY RUN ON'
VDOUT[992]=1
NCK1(IF[VORD[0014]EQ 0]NCK2
VUACM[1]='BLOCK DELETE ON'
VDOUT[992]=1)
NCK2 IF[VORD[0022]EQ 1]NCK4
VUACM[1]='SPINDLE OVERIDE'
VDOUT[992]=1
NCK4 IF[VORD[0031]EQ 1]NCK5
VUACM[1]='COOLANT OFF'
VDOUT[992]=1
NCK5 IF[VORD[011A]EQ 1]NCK6
VUACM[1]='R-SPNDL OVERRIDE'
VDOUT[992]=1
NCK6 IF[VRSTT NE 0]NCK7 (IF RESTART)
NCK IF[VORD[0011]EQ 0]NCK7
VUACM[1]='A INDIVIDUAL ON'
VDOUT[992]=1
NCK7 IF[VORD[001C]EQ 1]NCK8
VUACM[1]='LOAD MONITOR OFF'
VDOUT[992]=1
NCK8 IF[VORD[0110]EQ 1]NCK9
VUACM[1]='MA OVERRIDE'
VDOUT[992]=1
NCK9 IF[VORD[0106]EQ 1]NCK10
VUACM[1]='MB OVERRIDE'
VDOUT[992]=1
NCK10 IF[VORD[0143]EQ 0]NCK11
VUACM[1]='SYSTEM LINK ON'
VDOUT[992]=1
NCK11 IF[VRSTT NE 0]NCK12 (IF RESTART JUMP)
IF[VORD[0013]EQ 1]NCK12 (SINGLE BLOCK)
IF[VORD[0023]EQ 1]NCK12
VUACM[1]='FEEDRATE NOT 100'
VDOUT[992]=1
NCK12 IF[VRSTT EQ 0]NRTS (IF NOT RESTART JUMP)
NCKR1 IF[[VIRD[0030]+VIRD[0031]+VIRD[0032]]EQ 0]NCKR2
VUACM[1]='FEEDRATE TOO HI'
VDOUT[992]=1
NCKR2 IF[VORD[0013]EQ 1]NRTS
VUACM[1]='SINGLE BLK OFF'
VDOUT[992]=1
NRTS RTS
OCHKB
(IF[VTOFZ[2]EQ 0]NCK1
VUACM[1]='T-B2 NOT AT Z0.0'
VDOUT[992]=1)
NCK1 IF[VRSTT NE 0]NRTS (IF RESTART)
NCK13 IF[VORD[0012]EQ 0]NRTS
VUACM[1]='B INDIVIDUAL ON'
VDOUT[992]=1
NRTS RTS
OCHK1 (WITHOUT BARFEEDER)
IF[VORD[0015]EQ 0]NCK0
VDOUT[992]=1
NCK0(IF[VORD[0014]EQ 0]NCK2
VDOUT[992]=1)
NCK2 IF[VRSTT NE 0]NCK3 (IF RESTART)
NCK00 IF[[VIRD[0030]+VIRD[0031]+VIRD[0032]]EQ 0]NCK3
NCK IF[VORD[0023]EQ 1]NCK3
VDOUT[992]=1
NCK3 IF[VORD[0022]EQ 1]NCK4
VDOUT[992]=1
VDOUT[992]=1
VDOUT[992]=1
VDOUT[992]=1
VDOUT[992]=1
VDOUT[992]=1
NCK9 IF[VORD[0106]EQ 1]NCK11
VDOUT[992]=1
VDOUT[992]=1
NCK11 IF[VRSTT EQ 0]NRTS (IF RESTART)
VDOUT[992]=1
VDOUT[992]=1
NRTS RTS
As you can see, the sky's the limit on what you can do, but don't let it intimidate you. Most of it is just basic yes/no logic.
Best regards,
OkumaWiz can you send me your email on my PM.
