A CNC Cutting Machine is a numeric controlled machine used for complex cutting operations. In the numeric control, the manufacturing machine automatically operates via a programmed software. The cnc router allows for precision cuts at faster rate. Moreover, it is easy to operate and reduces the chances of human error. But, to get the best results, it is very important to select the CNC Cutting Machine carefully considering all the factors. So, here are some points to remember while selecting the CNC Cutting Machine.
Tips for the Selection of CNC cutting machine :
Type-The selection of the tools depends upon the type of the job you want to perform. A CNC Plasma-Cutting Machine Or a Jet-Cutting Machine is perfect for machining 2 D parts such as the cutting of the plate profile. CNC router machines are suitable for machining of soft materials like wood, plastic, particleboard, etc. On the other hand, CNC milling machines are perfect for machining hard metals like steel or iron;
Axis-The machines are available with 2-axis, 2.5-axis, 3-axis and more variants. The selection of the machine is crucial for determining its capability for producing the cut profile of plate. A 2-axis machine is apt for producing a gasket like plate. A 2.5-axis machine would move in three directions but not together for cutting a curved semi-circular plate. In this case, you will require a 3-axis machine. Similarly, a 5-axis machine is required for cutting circular cross sections;
Positional Accuracy-The positioning of the cutter is very crucial for the quality of cut and the final product. For fine engraving, the resolution of motor requires a precision on 0.0002" (0.005mm) whereas cutting wooden panels would need an accuracy of 0.005" (0.1mm). The cost of the machine depends upon the accuracy and precision of the machine;
Control system- The PC based control systems are used by most of the wood cutting machine manufactured nowadays. They run from the standard format file of the industry such as the ISO G-Code or HPGL. They are compatible with most of the software solutions and are very easy to use. Moreover, it is better to ensure whether the control system will work with third party software in case the control system is unique tothe 3D CNC Router Manufacturer In India. It is also important to check if the controller can be networked with the PC for file transfer or require a direct numeric control link from PC to the controller. Moreover , the data processing speed is also an important factor to consider;
The spindle speed and power is another thing that needs to be considered. Pointed conical or D-bit tools with high spindle speeds are required for fine engraving. The size of the work piece is another important thing to consider before purchasing a CNC Cutting Machine.
Author represents this article on the behalf of Banyan Tradelink, one of prominent Exporters and Suppliers of Cutting CNC Router Machine , offers Industrial Cutting Tools such as Stone Laser Die Board Cutting Machines, Laser Cloth Cutting Machines, Laser Engraving Machine, Laser Die Board Cutting Machine and Automatic Bending Machines. More in chinarouters.com
