585,665 active members*
3,000 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 2.2kw Spindle upgrade question
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    15362
    Re: 2.2kw Spindle upgrade question
    Quote Originally Posted by stargeezer View Post
    Great! Thank you very much.
    One last question, if you don't mind. just what should the rating for the braking resister be? I'm not sure I'll add one, but there have been times that I've wished I could get the spindle slowed quicker.
    This can be a tough one as some of these VFD's don't support a Braking Resistor,( Just some electronic parts missing ) I have never used one on these Huanyang Drives, some have though with good success, most VFD manufacturers have them already sized for each VFD size,these are for a normal 50/60Hz AC motor, yours is not a normal AC motor, and with not all the spec's available for your spindle, it can be hard to calculate for the correct size, so most that are using them are kind of guessing, I have attached a PDF that give information on how to calculate the Resistor size, but you may not have enough spindle motor spec's, to get it totally correct, I will see what else I can find as this comes up from time to time
    Mactec54
  2. #22
    Mar 2009
    5
    Just an update (said I would).
    My 4 HP, Huanyang VFD I bought is still working after 6 years now.
    Maybe I am just lucky.
    J.
  3. #23
    ericks Guest
    Quote Originally Posted by JonnyElectronny View Post
    J.
    What spindle motor are you using with this drive? Has it also lasted this long?
  4. #24
    15362
    J.
    You sized your VFD bigger than the spindle motor requirements, this is always the best idea to help with getting a long life from these drives or for any VFD Drive that is using single phase supply, having the Parameters set correct and wiring correct you have a long life as a result, most of these VFD Drives only fail from incorrect sizing of the VFD Drive bad wiring and Parameter setting
    I have more than 15 years on some of my VFD Drives that run everyday
    Mactec54
Page 2 of 2 12
  1. what spindle to upgrade to...
    By Us ill in forum Uncategorised WoodWorking Machines
    Last Post: 03-20-2014, 10:34 PM
  2. NM-145 Spindle Upgrade Kit
    By Novakon in forum Novakon
    Last Post: 05-24-2012, 04:35 PM
  3. R-8 SPINDLE UPGRADE
    By smallblock in forum Shopmaster/Shoptask
    Last Post: 08-13-2009, 02:21 PM
  4. Spindle drive upgrade question
    By Freddy Bastard in forum Tormach Personal CNC Mill
    Last Post: 02-09-2009, 07:02 PM
  5. Spindle upgrade
    By nagjames in forum Syil Products
    Last Post: 01-27-2007, 08:00 AM
