Hi, earlier this year I posted about a problem I was havingwith the spindle of my 1984 Okuma LB15 (OSP5000L control). Through thehelp of forum members & a local technician the fault was eventually foundto be the spindle motor speed sensor.
To prove this the technician told me to remove some covers& place a small heater fan so that it was blowing on the motor & leave itthere for a couple of hours. This worked & the spindle ran fine for therest of the day.
I then pulled the motor out & closed the gap between thesensor, which is a Fanuc A20B-9000-0010 & the toothed wheel by a couple ofthou, cleaned a few things & put it back together & all seemed ok.
This machine does not get much use; although I do run awarm-up program through it once every week or two. The other day I ran it for astraight 10 hours with no issues, however the following morning the originalproblem reappeared.
As we are into spring here in Australia the weather is startingto warm up, so I thought I would wait & try it later in the day…shefired up without a problem.
Based on this I have a couple of questions that I hopesomeone can answer:
- How does the ambient temperature affect thespeed sensor?
- Is it worth getting the sensor output signalcheck with a scope?
- If the sensor is stuffed, where can I getanother one or is there another ‘fix’?
Any help would be much appreciated
Thanks WC56
