Just thought I would add this: In the two images you can see I was trying to run a CAM job on a part to generate 2 sets of Gcode. I am a newb, so there are better way most likely.
Pic 1: Since I wanted to DRILL and separate that from the Milling portion - I excluded those in the Program Operations.
It would NOT exclude the Milling parts. Then I just tried moving the "End repeat" above the excluded parts and it works fine.
Just something for other functions possibly? Exclusions of Program Ops and placement of starting and ending function segments is key.
Attachment 294752
Attachment 294754
