Re: Finally got a dm3000 and looking to convert to mach 3
Congrats on the purchase. You have some great iron.
Now to address some of your questions.
Bardac 1600i, it is a very good unit. You can find them much cheaper on Ebay. Well under 200 if you are persistent. On the other hand there is a perfectly good spindle control board already on your lathe. Try to learn how to interface with it. There is a manual/auto spindle switch. Trace those wires back and interface your new controller with it if you go that route.
The G540 is able to drive 4 axis, nothing else is needed. You will actually have an extra driver in case you fry one. You need 3. 1 for X, Z and the tool changer. The G540 is a well respected unit that is user serviceable. Leadshine also makes a similar unit the Mx3660 or the Mx4660 which would mimic the g540's extra drive. However the Mx series maxes out at 5amp per axis, the G540 at 3.5amp.
The multiple voltage power supply is good for a variety of voltages you would need. 48v for the drivers, 24v could be for relays, limit switches. Same for the 5v tap.
I believe MRM uses the c10 along with a 2nd PP to connect his other switches. A pokeys could do that too.
And last but not least a 20 amp EMI filter. Again this is likely already built in if you know how to identify it. Just reuse the original. It is to filter noise and help eliminate any false triggers.
There is an article somewhere on the web about how to interface with the original electronics. I had already gutted mine prior to finding the article and or understanding half of the parts I was looking at.
A lazy man does it twice.
