585,753 active members*
4,020 visitors online*
    Jan 2013
    10
    Yasnac MX1/2/3 Drip Feed DNC Question
    Does the MX1 (or 2 or 3) control have any type of data buffer for drip feed DNC operation? I'm personally unfamiliar with the MX1 but from my research I understand that the memory upgrade is limited to 128K which would necessitate a DNC operation for a larger program.
    It also seems that the "typical recommended" baud rate is 2400 (or 4800?) which has me concerned that small distance moves (.003" at 20 ipm) will complete well before the next line has had time to transmit, hence the buffer question. The entire program(s) typically will not be so dense but if there were no Comm buffer then at these short move points what happens? Does the motion cease for some very small amount of time until the next line has been transmitted? That doesn't sound good. Lots of stops and starts with very jerky motion...
    Curious as to others experiences with this control using DNC operation.
    Any experiences, even with running the MX controls with this type of program directly from memory are welcome.
    THX.
    Jan 2015
    42
    Re: Yasnac MX1/2/3 Drip Feed DNC Question
    I can help... send me an email: [email protected]
    Jun 2003
    241
    Yes, this is a very old thread BUT, I'm getting a Matsuura MC-510V with an MX3 controller and will need this information as well.
  1. yasnac mx1 drip feeding
    By matosjulio in forum CNC Machining Centers
    Last Post: 03-06-2020, 02:25 PM
  2. drip feeding yasnac mx2 (mori mv40)
    By ross33912 in forum Mori Seiki Mills
    Last Post: 12-09-2012, 04:54 PM
  3. drip feeding yasnac mx3?
    By maz43 in forum G-Code Programing
    Last Post: 09-25-2009, 10:34 PM
  4. Drip Feed to Yasnac LX3 vis RS232
    By Zig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-21-2008, 02:24 AM
  5. drip feeding problems on a Yasnac MX3
    By 9566317 in forum DNC Problems and Solutions
    Last Post: 11-13-2007, 09:04 PM
