Originally Posted by
gfacer
This would be an issue of cut start and end ramping, nothing to do with tabs. Bobcad probably has what you need, probably called lead in and lead out.....ramping is good, but your issue isn't ramping related, exactly, probably mostly slightly lower machine rigidity than needed. Force of the z movement moves the spindle a bit. This would not always should up for the exit, so maybe a backlash issue or some other small problem. However, the lead in and lead out should make the marks go away even without solving the cause.
