585,885 active members*
6,203 visitors online*
Results 1 to 8 of 8
    Oct 2015
    Post G76 doesn't work
    Hi
    im a student and my english is poor so sorry on advance.we were making thread on campro cpl-208, it only passed 2 times the lenght of thread. thread is m30x1.5. any ideas what would be wrong? i dont remember accurate measures but it was something like this. solids diameter 29.9 and threads bottom Dia 28.160.
    2932
    Re: G76 doesn't work
    Post your program here so we can see what might be the problem.
    Oct 2015
    this is part of it
    G0 x29.9 z5
    G76 p010160 Q50 R0.05
    G76 x28.160 z-30. R0. P920 Q2000 F1.5
    should there be dot after p920?
    first pass goes x29.700 and the
    second one at x28.1 if i remember
    correctly, problem is that it should
    do more passes.
    Feb 2006
    1792
    Replace Q2000 by Q200, for more passes.
    Oct 2015
    TY so much it worked
    Feb 2006
    1792
    You are welcome.
    Mar 2014
    19
    sinha_nsit
    G76 x28.160 z-30. R0. P920 Q200 F1.5
    Where you get P and Q numbers - some table?
    Sep 2010
    1230
    Quote Originally Posted by Readme00 View Post
    sinha_nsit
    The P address is the Height of the Thread Form. You will get this information from books listing Thread Specifications such as Machinery's Handbook.
    The Q address specifies the Depth Of Cut for the first threading pass. This value will vary depending on the rigidity of the workpiece setup and other factors. Because the algorithm that calculates each new depth of cut uses this First Depth Of Cut as the base number, the Q value should be made as great as the Threading Insert and the Workpiece rigidity can tolerate.
    Regards,
    Bill
  1. Meldas 330 G54~G56 doesn't work
    By guhl in forum Mitsubishi controls
    Last Post: 12-22-2014, 10:44 AM
  2. G10L50 doesn't work
    By martyc@blumlmt in forum Fanuc
    Last Post: 09-05-2012, 09:53 PM
  3. probe doesn't want to work
    By metalmansteve in forum Haas Mills
    Last Post: 06-25-2012, 10:38 PM
  4. BobCAD CAM Doesn't Work!!!!
    By aldepoalo in forum BobCad-Cam
    Last Post: 05-04-2012, 08:58 PM
  5. G72.1, G72.2 doesn't work!
    By Maxz in forum G-Code Programing
    Last Post: 11-18-2011, 05:16 PM
