585,996 active members*
3,850 visitors online*
IndustryArena Forum > Hobby Projects > Wooden Clocks > G-code plans for a cnc router
    Jan 2015
    9
    Hello Everyone,
    If you want to build a rocking horse you go on line and purchase the plans trace them out and cut them on your bandsaw, drill them in your drill press, sand them with your sander and put it together.
    My question is can you purchase plan with G-code for a CNC Router for example a hope chest, cabinet doors, clocks, etc?
    Thank you,
    Philip
    Re: G-code plans for a cnc router
    You may be able to find some, but it's not common.
    The reason is that not all g-code is universal, and ideally, it should be tailored to your specific machine.
    Some controls may not support certain g-codes, and feedrates will tend to be different from machine to machine.
    Personally, I would never run g-code on my machine that was created by someone else.
  1. Does anyone have plans for this CNC Router
    By 94vette in forum DIY CNC Router Table Machines
    Last Post: 08-13-2010, 12:48 AM
  2. Looking for plans I used for CNC Router
    By Kraig1 in forum Open Source CNC Machine Designs
    Last Post: 09-07-2009, 06:03 PM
  3. G-Code Router Plans ?
    By deleteallusers in forum DIY CNC Router Table Machines
    Last Post: 05-04-2007, 07:47 PM
  4. Plans for a CNC Router
    By DAB516 in forum DIY CNC Router Table Machines
    Last Post: 03-30-2007, 08:00 PM
  5. My CNC Router Plans
    By Clyde in forum DIY CNC Router Table Machines
    Last Post: 04-18-2004, 04:32 PM
