585,729 active members*
5,012 visitors online*
    Oct 2015
    How to measure spindle speed
    I’m building a cnc lathe and I have my X and Z axis working, but I now want make it capable of cutting threads.
    1: How do I connect a rotary encoder to mach3, is it done through the breakout board as I don’t seem to have a input option for spindle speed?
    2: Can I use the rotary encoders sold on ebay, see link or will I need to make my own?
    but my main question is, how do I connect the RPM pulses to MACH3?
    Encoder 6mm Shaft 600P/R Incremental Rotary AB phase for Length Measurement | eBay
    Apr 2003
    354
    Re: How to measure spindle speed
    Unfortunately Mach3 won't work with an encoder unless you have an external motion controller (Smooth Stepper, CSMIO, etc) If you're using the parallel port, it will only work with a single pulse/rev device, usually opto sensor & slotted disc. I use a CNC4PC C3. Cheap & works well.
    Threading with Mach3 has been challenging for me because my spindle drive wasn't powerful & steady enough for cutting threads in steel over 16mm dia. Had to build a 1:4 reduction belt drive to get it to work.
    24220
    You could also look at Kflop Kmotion.
    Al.
    Albert E.
  1. Fanuc AC Spindle Drive speed does not match S-code speed
    By serickson in forum Spindles / VFD
    Last Post: 10-13-2014, 01:18 PM
  2. How can I Measure the work-load on my Colombo Spindle?
    By NardisAmps in forum Spindles / VFD
    Last Post: 11-08-2013, 01:32 AM
  3. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
