I recently purchased a tree 220 journeyman machine with a centurian v controller. It has been sitting for the past five years and after hooking it up I have the following problems.
1 you can start it up and use as long as you are holding the little green reset button, let go of it and everything dies and gives you a 450 e-stop. Is this a correctable problem or is it in the board?
2 since this is a two axis machine with hand wheels on the x and y is there a way to disable the drives? (once i get the little green button fixed)
This would enable me to use this as a manual machine still utilizing the DRO much like bridgebort EZ-trak
thanks, any help would be great
tractorguy
