after finishing my very first router made of MDF I have decided to move to next level - I opted for aluminium extrusions and plates. Although I like projects like these very much, I would like this to be my final build. I want the router to serve me, not vice-versa. I will reuse components from the first build and buy missing stuff. As the price tag is completly different compared to MDF build costs and I want to build high quality machine, I would love to hear any criticism or suggestions you might have before I buy items for final design.
This is what I have already available:
- 4x NEMA23 381 oz/in 3.5A Dual Shaft Stepper Motor (KL23H2100-35-4B)
- 4x Oldham type motor couplers
- 4x Leadshine´s EM705 stepper motor drivers
- 2x 48 VDC 7.3 A power supplies
- Ethernet Smoothstepper with C25 breakout board
- 2.2 kW water cooled Chinese spindle with VFD inverter
- Water cooling set with radiator
- Misc. HW like emergency push buttons, Hall effect limit switches, spidle speed controler etc.
My shopping list (vendors are selected with respect to availability and reviews from other builders):
- Hiwin ball linear guides with blocks
- Hiwin ball screws, nuts, bearing units
- Misumi aluminium extrusions, brackets, joints etc.
- 6061 T6 aluminium plates
I have reviewed many extrusion designs and I like this and this the most. My metal processing options are rather limited so I have to buy e.g. bearing units instead of making them or to use cutting service to precisely cut extrusions to specified lengths. I definitely don´t want to mess this part by being imprecise.
My idea for this build is as follows:
- Footprint about 1200 x 900 mm, work area about 900 x 600. This might slightly change.
- I want the gantry to be the longest axis. I would like to have option to machine larger parts when needed.
- Supported rails, supported work table.
- 4 mm pitch screw is very little. As Gerry wrote, I need higher pitch, 8 - 10 mm. I choose 10 because of availability.
- The machine must be as rigid as possible - I rather overstep some parameters.
- MDF work table surface.
- I plan to weld steel base frame for machine later.
So far, the upright will not be straight up but will be sloped to move the center of gravity of the completed gantry between blocks on Y rail as much as possible.
Before I move on with design I would like you to advice me on couple of things, one by one. I will be thankful for any feedback!
Thank you.
