585,987 active members*
4,411 visitors online*
    Oct 2015
    What Kind of Feature
    Hi, I am new to FeatureCAM and I need to use mill turn to mill a simple open ended slot across the front of a piece of 25mm dia bar. The slot needs to be 8mm wide and 20mm deep, so what kind of approach should I take regarding the kind of feature to select.
    The machine is a Doosan Lynx 220 Y axis.
    Also, The manual ISO code for this feature would be good.
    Thanks.
    Jul 2010
    369
    Re: What Kind of Feature
    You would want to either do a "Slot" from dimensions or a "Groove" from a curve.
    Good Luck~!:cheers:
    Aug 2012
    54
    :0069 (SLOT)
    (DOOSAN PUMA 2600Y)
    (BAR DIA = 25.0MM)
    (WITH OF SLOT = 8.0MM)
    (DEPTH OF SLOT = 20.0MM)
    (CUTTER DIAMETER = 6.0MM / 4FL)
    (MATERIAL ST/ST 316)
    N0 (SETTING PARAMETERS)
    G21 G40 G80 G18
    G28 V0 B0
    G130 X336. Z650.
    G30 U0 W0
    G10 P0 X0 Z0 C0
    G10 L2 P1 (Z?) (G54 VALUE )
    G10 L2 P2 (Z?) (G55 VALUE )
    M01
    N01 (ROUGH1 SLOT1 M/S)
    (ENDMILLM0600:4REG-ROTARY Z)
    G40 G80 G18
    G28 V0
    G30 U0
    G30 W0
    T0101 (CHANGE IF NEEDED)
    M35
    G97 S1212 M03 P12
    G28 H0
    G50 C0
    G00 G98 G54 Z25.0 C0.
    G17 X0. Y-0.25
    Z3.0
    M89
    G01 Z0.03 F43.63
    X-12.0 Z-0.427
    X0. Z-0.885
    X-12.0 Z-1.342
    X0. Z-1.799
    X-12.0 Z-2.256
    X0. Z-2.714
    X-12.0 Z-3.171
    X0. Z-3.628
    X-12.0 Z-4.085
    X0. Z-4.543
    X-12.0 Z-5.0
    X12.0 F87.26
    G03 Y0.25 I0. J0.25
    G01 X-12.0
    G03 Y-0.25 I0. J-0.25
    G01 X0.
    X-12.0 Z-5.427 F43.63
    X0. Z-5.885
    X-12.0 Z-6.342
    X0. Z-6.799
    X-12.0 Z-7.256
    X0. Z-7.714
    X-12.0 Z-8.171
    X0. Z-8.628
    X-12.0 Z-9.085
    X0. Z-9.543
    X-12.0 Z-10.0
    X12.0 F87.26
    G03 Y0.25 I0. J0.25
    G01 X-12.0
    G01 X0.
    X-12.0 Z-10.427 F43.63
    X0. Z-10.885
    X-12.0 Z-11.342
    X0. Z-11.799
    X-12.0 Z-12.256
    X0. Z-12.714
    X-12.0 Z-13.171
    X0. Z-13.628
    X-12.0 Z-14.085
    X0. Z-14.543
    X-12.0 Z-15.0
    X12.0 F87.26
    G03 Y0.25 I0. J0.25
    G01 X-12.0
    G01 X0.
    X-12.0 Z-15.427 F43.63
    X0. Z-15.885
    X-12.0 Z-16.342
    X0. Z-16.799
    X-12.0 Z-17.256
    X0. Z-17.714
    X-12.0 Z-18.171
    X0. Z-18.628
    X-12.0 Z-19.085
    X0. Z-19.543
    X-12.0 Z-20.0
    X12.0 F87.26
    G03 Y0.25 I0. J0.25
    G01 X-12.0
    G00 Z25.0
    M90
    Z-10.0
    M89
    (FINISH)
    G01 X-10.807 Y-0.8 F68.09
    G03 X-9.234 Y-1.0 I0.787 J1.45 F34.05
    G01 X12.0 F68.09
    G03 Y1.0 I0. J1.0 F34.05
    G01 X-12.0 F68.09
    G03 Y-1.0 I0. J-1.0 F34.05
    G01 X-9.234 F68.09
    X-3.234
    G03 X-1.661 Y-0.8 I0. J1.65 F34.05
    G01 X-0.468 Y-0.25 F68.09
    X-12.0
    Z-20.0
    X-10.807 Y-0.8
    G01 X12.0 F68.09
    G01 X-12.0 F68.09
    G01 X-9.234 F68.09
    X-3.234
    G00 Z25.0
    M90
    G28 V0
    G30 U0 M09
    G30 W0
    M05 P12
    M34
    M01
    M30
    Jul 2010
    369
    Another method if you use an 8mm diameter cutter.
    ( ROUND STOCK - STEEL-10XX. OD 25 ID 0 Z 100 )
    (TOOLING)
    ( T1 = .315 EMILL-rotary Z)
    ( T1 MAXZ= -20)
    N0101 (TOOL=01 PASS=01)
    ( MILLING: .315 EMILL-ROTARY Z )
    (GROOVE)
    G17 G21 G40 G54 G80 G98
    M45
    G0 T0101
    G97 S2510 M13
    G0 C0.
    M68
    G0 X-33.0 Y0. Z25.0 M8
    Z3.0
    G1 Z-1.0 F174.0
    X33.0
    Z-2.0
    X-33.0
    Z-3.0
    X33.0
    Z-4.0
    X-33.0
    Z-5.0
    X33.0
    Z-6.0
    X-33.0
    Z-7.0
    X33.0
    Z-8.0
    X-33.0
    Z-9.0
    X33.0
    Z-10.0
    X-33.0
    Z-11.0
    X33.0
    Z-12.0
    X-33.0
    Z-13.0
    X33.0
    Z-14.0
    X-33.0
    Z-15.0
    X33.0
    Z-16.0
    X-33.0
    Z-17.0
    X33.0
    Z-18.0
    X-33.0
    Z-19.0
    X33.0
    Z-20.0
    X-33.0
    G0 Z25.0
    M9
    M5
    M46
    M69
    G28 V0
    X250.0 Z125.0
    M30
    Good Luck~!:cheers:
  1. Replies: 8
    Last Post: 07-18-2012, 10:51 PM
  2. Two of a kind - almost.
    By cncadmin in forum EnRoute
    Last Post: 12-18-2011, 10:00 PM
  3. Dill feature without center drill feature
    By LockTech in forum BobCad-Cam
    Last Post: 08-25-2011, 02:38 PM
  4. What Kind Of CMM?
    By ajl6549 in forum Calibration / Measurement
    Last Post: 03-01-2007, 06:57 PM
