584,860 active members*
4,987 visitors online*
IndustryArena Forum > CAM Software > CamBam > Converting drawing in mm to inches
    Sep 2011
    474
    I had to draw out a part in mm, now I'd like to cut it out using standard 1/4 and 1/8 endmills. Cambam wont seem to convert my mm drawing into inches. Is there a way to do this?
    Thanks,
    Feb 2007
    4553
    Re: Converting drawing in mm to inches
    SwampDonkey,
    Check this out:
    CamBam 0.9.8 documentation - Transformations
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2012
    14
    You can just scale the drawing up/down when converting between imp and metric units (as per Jalessi). In your case you can also just convert the imp measurements of your end mill to metric.
    Nov 2012
    1267
    Unless you have other reasons to convert your drawing to inches, just tell CamBam you have 6.35mm and 3.175mm endmills instead of 1/4" and 1/8".
    edit: oops, sorry, somehow stumbled upon a year old post.
  1. Autocad LT 2008 Total inches in drawing?
    By Gawker in forum Autodesk
    Last Post: 12-06-2022, 02:05 PM
  2. Converting drawing for Burny CNC Plasma Cutter
    By Turbo1zz in forum Waterjet General Topics
    Last Post: 07-06-2017, 07:10 PM
  3. Replies: 3
    Last Post: 04-10-2015, 04:42 PM
  4. Star SV32 w/ Fanuc 16i-T not converting to Inches
    By pmrairokn in forum CNC Swiss Screw Machines
    Last Post: 05-19-2010, 04:42 PM
  5. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
