585,743 active members*
5,022 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Boring 6061 - horrible surface finish!
Results 1 to 6 of 6
    Aug 2015
    10
    I am attempting to bore 65mm holes in 4" aluminum bar. A photo of the result is attached. It's ugly! I have experimented with alot of variables but still get this tearing of the metal instead of a clean cut.
    Machine: Tormach PCNC 1100 series 3
    Controller: PathPilot
    Tool: 1/2" Glanze through-coolant boring bar (steel)
    Insert: CCMT, tried one for steel and one for aluminum with the same result
    Surface speed: 150-500 meters/min
    Feed rate: 550-800 mm/min
    depth of cut: 0.25-0.5mm
    Insert is parallel to X-axis and centered in the bore
    All the other cuts on the machine are working great. Facing, turning, parting are all no problem. What am I doing wrong with boring?
    Jan 2013
    630
    Re: Boring 6061 - horrible surface finish!
    That's fairly aggressive I would think. Looks like it chattered a lot.
    Nov 2003
    287
    Are you using the shortest boring bar possible? Just long enough to reach bottom of bore.
    Aug 2015
    10
    Quote Originally Posted by vertcnc View Post
    The hole is only 3/4" deep, The boring bar stickout is about 1.25" right now. If I eliminate the through-coolant, I could choke is up right next to 3/4".
    On my manual lathe, I can run a lot more stickout than that with no chatter. And that's with a cheaper, thinner boring bar.
    Jun 2013
    1041
    Try again at 3-500 rpm 50-80mm per minute. I've not used the tormach but when I'm having trouble boring that range almost always works well.
    Ben
    Aug 2015
    10
    Thanks for all the help and suggestions here. I finally fixed the problem by a combination of choking up on the boring bar as far as possible, re-routing the coolant line to maintain through-coolant, .25mm depth of cut, 157 m/min surface speed, and 550 mm/min feed rate.
  1. Horrible surface finish from endmill
    By skray775 in forum MetalWork Discussion
    Last Post: 11-03-2012, 05:42 AM
  2. Best milling finish on 6061
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-31-2011, 03:35 PM
  3. 6061 aluminum finish ??
    By twocik in forum Mass finishing equipment/media/strategies
    Last Post: 11-01-2008, 05:37 PM
  4. Very rough finish when turning 6061-T6 ... why?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2008, 11:24 PM
  5. Getting best surface finish OD turning 6061 AL?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2007, 04:57 AM
