585,996 active members*
4,856 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, need some variable
Results 1 to 11 of 11
    Jun 2015
    4154
    Question pls, need some variable
    Hy, please for lb3000, i need variable to read compensation radius on X and Z axis, event if they are the same.:drowning:
    Jun 2008
    372
    Re: pls, need some variable
    Try these
    VNSRX X-axis nose radius compensation amount VNSRX[12] = 0.020
    VNSRZ Z-axis nose radius compensation amount VNSRZ[12] = 0.020
    Jun 2015
    4154
    hello, thx 4 answer ... please, i need it a bit different
    For example, if i have in code T020202, i dont want to call vnsrx[02], but simple vnsrx ...
    So, i need to read the radius compensation for the tool that is active, without pointing to that tool again.
    T020202
    do something with vnsrx[02]
    i change after a while the tool, so i will need to modify the program in 2 places :
    T030303 ( modify )
    do something with vnsrx[03] ( modify )
    i would like to modify only the tool, so to make only one modification :
    T030303 ( modify )
    do something with vnsrx - should work automatically for the active tool
    maybe is possible ....
    Feb 2005
    303
    VATOL is the tool currently in the spindle, so how about:
    VNSRX[VATOL]
    Jun 2015
    4154
    hi, vatol is not working ... i have osp-p300L ...
    Feb 2005
    303
    Sorry, my bad... turning centers use VETLN rather than VATOL.
    Jun 2015
    4154
    k, i'll try it tomorow ... also, vatol should work on mills ?
    Feb 2005
    303
    VATOL is the tool number that is currently in the spindle on mills... a word of caution, VATOL contains the tool number from the most-recently completed tool change. 99% of the time, that should be the tool currently in the spindle.
    Jun 2015
    4154
    thank you, it worked
    * what case is 1% ?
    Feb 2005
    303
    Glad it worked!
    If the power drops out during a tool change, then the variable may still contain the previous tool number, and of course, manually changing a tool.
    Jun 2015
    4154
    thank you
  1. Variable zero
    By Dave Elliot in forum DNC Problems and Solutions
    Last Post: 05-28-2010, 10:38 AM
  2. Variable
    By cncboy1 in forum Okuma
    Last Post: 10-30-2009, 04:23 PM
  3. Variable changes
    By TNorbut in forum Controller & Computer Solutions
    Last Post: 07-23-2008, 01:16 PM
  4. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
  5. IF variable = bla THEN do this ELSE do that ?
    By iMisspell in forum G-Code Programing
    Last Post: 07-31-2006, 04:57 AM
