585,987 active members*
4,359 visitors online*
    Aug 2013
    21
    g-code translator
    Is there a program out there that can change the g-code written for one machine into g-code for a different machine. I have an AXYZ router A2MC with ATC and I want to use Fusion 360 but it doesn't have a post processor for my machine.
    Feb 2006
    992
    g-code translator
    It had been so many years away from the bussiness, so I'm not sure. If you willing to pay i'm sure someone will take a look at this. However, it's not that hard to translate g-code for one machine to other. I don't remember exactly but back then I used Microsoft Word to make modification, it call "macro record and play" you just have to record the note one, next time you just hit play it will make all necessary change in seconds.
    The best way to learn is trial error.
    May 2016
    4
    Re: g-code translator
    Can you post some of the code that Fusion 360 will output and some code that works on your machine? I could maybe customize something for a fee if you're interested.
    Jun 2003
    205
    Here's a very powerful option in KipwareXC®.
    KipwareXC -User configurable CNC G Code Conversion Software from Kentech Inc.
    Completely user configurable and you can build as many different Profiles as required to convert between multiple formats for multiple machines if required.
    It can be used very effectively as a "post" alternative.
  1. G code translator for Galil
    By harrymen in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-13-2014, 08:49 AM
  2. Do You Want a G Code Translator?
    By RFB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-05-2012, 02:11 AM
  3. STEP to Surfcam Translator
    By g_saun in forum Surfcam
    Last Post: 01-13-2011, 05:31 PM
  4. Gibbs to Mastercam translator ???
    By ED209 in forum Mastercam
    Last Post: 01-31-2010, 07:54 AM
  5. Macro Translator
    By ArchieF in forum NCPlot G-Code editor / backplotter
    Last Post: 12-23-2007, 05:19 PM
