585,764 active members*
4,124 visitors online*
Results 1 to 7 of 7
    Sep 2015
    A2100 RT MB Fail
    CINCINNATI MILACON
    ACRAMATIC A2100 CNC CONTROL
    RealTime CPU MotherBoard
    AA 653781 – 205
    PBA 647633 205
    AMIBIOS ©1992 Americian Magatrends, INC
    BIOS Version 1.00.06.BR0
    The battery in the RT CPU MB has failed, this resulted in a loss of CMOS settings and an NVRAM fault / halt on boot as follows:
    NVRAM Checksum Error, NVRAM Cleared
    NVRAM Data Invalid, NVRAM Cleared.
    A new battery was installed, the CMOS was set according to the Siemens field service documentation, the CMOS and RTC settings are now retained on power down.
    Whilst setting the CMOS was a simple matter the NVRAM fault cannot be cleared by:
    Any combination of CMOS settings;
    Mother Board switch 4 - CMOS Clear (NVRAM); or
    Removal of the battery and MB power.
    This may indicate a BIOS / NVRAM corruption or hardware fault.
    Extensive testing of the MB with diagnostics utilities has not revealed any hardware issues.
    The next step in the repair process should be to re-flash the BIOS and apply any custom PnP settings with an ISA Configuration Utility.
    This should eliminate all possible field repair procedures before a MB swap is concluded.
    On reading the CNC Zone posts on this issue, I believe Siemens readily shared these files with CNC Mill users.
    Would it be possible for someone to share the BIOS and NVRAM flash files from Siemen’s / Cincinnati Milacron with me.
    If not could you please advise who I can contact to source these files.
    As the CNC Mill has multiple faults I am not inclined to swap out the RT MB at this stage without exhausting all possible field repairs as the expense may be unjustifiable if the Mill is beyond economical repair.
    Any assistance with this issue is appreciated.
    John
    Nov 2015
    Re: A2100 RT MB Fail
    whats the pt# of the realtime brd
    Sep 2015
    Hi Tech2100
    Thanks for your interest.
    Posted all the relevant information except the most important one, oops.
    PN: 3-424-2171A01
    REV: A
    Hope this is what your after.
    John
    Sep 2009
    45
    That would be Mark Nichols at MAG, or rather Fives Group since they bought MAG. He can e-mail you the files. He's at [email protected]
    Sep 2015
    Thanks Bob
    I will send an Email now.
    Fingers crossed.
    John
    54
    Thats what I get when the wS board goes out. The one on the left. Clearing memory and starting over works. you have to put the parameters in the WS board again but that is no problem.
    David at [email protected]
    Feb 2008
    12
    hello for all,who cleared CMOS in RT computer. i get any photos, one of A2100 - with Siemens and one with Milacron, older "whitehead" with CRT. In Siemens and newer milacron "redhead" with LCD case, it has board with energy managment option,which in factory settings is on. So, first what you must do is disable power managment. It is RT board. This settings are working:
    Siemens and propably any new machines
  1. A2100 Realtime fail
    By slowlearner in forum Cincinnati CNC
    Last Post: 05-17-2018, 05:58 PM
  2. POWER FAIL! POWER FAIL!!!
    By christian1971 in forum DNC Problems and Solutions
    Last Post: 10-25-2011, 01:02 PM
  3. Solid CAM Fail
    By mr chris in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-05-2011, 10:24 AM
  4. 325 PROC WDT FAIL
    By ramsey321 in forum Tree
    Last Post: 09-14-2010, 04:47 PM
  5. Lube Fail
    By CC714 in forum Fanuc
    Last Post: 01-24-2008, 05:39 PM
