585,712 active members*
4,024 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Theories-opinions on hydraulic forces on side action cores?
    Dec 2009
    100
    I'm having a disagreement with a colleague about how to neutralize forces on cores. I don't believe there is such a thing as "neutralizing" the forces, but he believes that if the core enters a bore inside the mold (see image HOLE-SHUT-OFF.jpg) , there will be no hydraulic forces on the core. I believe this is only true if the hole is vented to atmosphere, in which case the axial forces on the core will be the same, but it's a moot point as it isn't possible in this mold, anyway. I maintain that when using an air cylinder to push the cores in, it is necessary to use locks and wedges (cams) to hold the cores in position, no matter what kind of "socket" or "hole" the core engages with, because the only escape route to atmospheric pressure is through the core print. I've been building molds for years, and I've never built one without some kind of provision for holding the cores in against the hydraulic pressures generated by injection of the plastic. The material is Nylon, 33% glass filled, the cores are approx 1" in diameter. Please see the pictures below. Any opinions?
    Attachment 296668
    Attachment 296670
    Re: Theories-opinions on hydraulic forces on side action cores?
    the side action core looks like it has a step on it, correct? If so, it has molding surface area in which case you will need to lock it by a wedge or core lock cylinder (which are garbage) Even if there was no molding surface area and you were just molding a through hole, then it's still good practice to lock it some how, wedge preferred but you could maintain hydraulic pressure on the cylinder during injection.
    I personally would never have a side action that wasn't locked somehow. Since the side action core seals against steel there is the chance that flash could get in between the two and blow it back
    Dec 2009
    100
    It does have a step in it to create an edge-break around the hole in the molded part. My thinking is the same as yours; I have never even considered building a mold without locking the cores in.
    I looked into the price of a locking hydraulic cylinder ($1500 and up), and you say you don't like them anyway.
    Jun 2018
    Quote Originally Posted by Concepts_Design View Post
    Old Thread I know.
    Hard to find information on locking cylinder opinions
    I'm just curious why you find locking cylinders to be garbage?
    Thanks!
  1. Side Mounted Hydraulic Steady Rest
    By kstephendaniel in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-18-2014, 07:04 AM
  2. Opinions on side mounting a vice (pictures included)
    By Cknoble1 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 07-29-2011, 04:53 AM
  3. sand cores
    By kirby in forum Casting Metals
    Last Post: 07-28-2011, 03:10 AM
  4. Drawing 3D foam wing cores for RC airplanes V23
    By bchristal in forum BobCad-Cam
    Last Post: 04-25-2011, 06:23 PM
  5. Using Anviloy for cores
    By 9566317 in forum Moldmaking
    Last Post: 04-10-2008, 01:35 AM
