Re: CO2 Laser tube 60 W doesn't cut
So first thing is I find the power setting should be min max at the same setting - otherwise it just does the lower value. The I would post more info of what you can achieve. 15mm/s for a 60 at 50% power seems a bit low but I don't cut wood (and mine is 130w). So if you are cutting it at all (and just not through), lower the speed or do multiple passes. Also hook up a multimeter to the outgoing terminal or return leg (ie NOT High Voltage side) and ready the MA used vs the rated working range - you may be able to up the power. Often "60w machines" are the max possible, but the tubes are rated 40w (really they are 40w machines) - you should be able to tell by the length of the tube and some research if no stickers are present.
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
