585,885 active members*
6,253 visitors online*
Page 4 of 9 23456
Results 61 to 80 of 168
  1. #61
    Feb 2006
    213
    Quote Originally Posted by JLT View Post
    Not so far but I don't take deep cuts.
    even if you did take deep cuts seems to me all it would take is a rib on the outsides of the gantry to stiffen it up.
  2. #62
    Sep 2005
    35
    Something like this?
  3. #63
    Aug 2004
    3215
    JLT, That looks like it will work very well
  4. #64
    May 2005
    8
    JLT,
    I have been thinking of nothing else for days, ever since my attention was drawn to your video on the Mach list. Before I launch into a couple of questions; my admiration for your invention is profound, and for me the beauty is in the simplicity. All over the world there are guys saying, I can do that, and scrambling to copy you.
    I see you define yourself as a hobbyist, but can I suggest you name the device? The JLT auto changer doesn't quite cut it, but if the T stood for say, Thompson, the Thompson Tool Tray has a ring about it and it might well catch on. Any family name starting with T should work, alliteration has a way of sticking with people. Its not money, but fame in small parts can be rewarding.
    The questions I had are, is there anything different to the High Tech Systems device about the rapid changer you made, other than dimensions..? I would like to buy their system as I do not have the skills or time to make it, plus I have bought gear from them and it is lovely kit.
    Secondly, you mentioned you used Sheetcam to drive the tool changer, did you just program moves that mimicked drilling and cutting moves in that specific location? If so, how did you get the machine to locate the tools, did you put the work in a specific location, or did you use a combination of Machs machine coordinates and home switches to find them?
    Best Wishes
    Chris
    Sydney
    Australia
  5. #65
    Sep 2005
    35
    Hi Chris,
    The only modefication to the High Tech Systems Rapid Changer was the mounting shaft to fit the router 1/2" . They have that option now.
    I don't use Mach but I'm sure the same thing that I do could be implemented with it.
    TurboCNC stores all tool length offsets so you don't put tool length offsets in Sheetcam.
    I do all cutting in Fixture 1 (G54).
    Home all axes with no tool (T0) and no Fixture (G53) at the start of the day or week
    All tool changes are done with no Fixture (G53).
    Set your work starting ref. when in G54 and reverence tool (T0) in the chuck and TurboCNC set for T0.
    G-Code snippet for TurboCNC tool change.
    This is generated with Sheetcam Post processor for TurboCNC.
    N0110 ;------------------------------
    N0120 ;
    N0130 ;Trudgen ATC for Joe's Model 2006 Router.
    N0140 #100=6
    N0150 G53
    N0160 M5
    N0170 M9
    N0180 T0
    N0190 G00 z-1.5
    N0200 G00 X2.5 Y[23.5-(((#101-1)*1.500)+1.78)]
    N0210 G00 X1
    N0220 G00 Z-3.812
    N0230 G00 X0
    N0240 G01 Z-3.2 F10
    N0250 G00 Z-1.5
    N0260 G00 Y[23.5-(((#100-1)*1.500)+1.78)]
    N0270 G00 Z-3.000
    N0280 G01 Z-3.812 F10
    N0290 G00 X2.5
    N0300 G00 Z-3 X4
    N0310 G54
    N0320 #101=#100
    N0330 T6 ;Drill, 0.125 inch diameter
    N0340 ;
    N0350 ;--------------------------------
    This is the Sheetcam Post code that I added for the changer that generates the code above for a tool change.
    #100 and #101 are TurboCNC user variables.
    function toolchange()
    text (" ;------------------------------\n")
    text (" ;\n")
    text (" ;Trudgen ATC for Joe's Model 2006 Router.\n")
    text (" #100=")
    number (tool, "0") --Tool # to pickup
    text ("\n")
    text (" G53\n") --No Fixture
    text (" M5\n") --Spindle off
    text (" M9\n") --Vac off
    text (" T0\n") --Switch to ref. tool
    text (" G00 z-1.5\n") --Safe height
    text (" G00 X2.5 Y[23.5-(((#101-1)*1.500)+1.810)]\n") --go to tool # to put back
    text (" G00 X1\n")
    text (" G00 Z-3.812\n") --unload pos.
    text (" G00 X0\n") --park pos.
    text (" G01 Z-3.2 F20\n") --Pull off holder slow to alow for sticking
    text (" G00 Z-1.5\n") --rapid up to clear double ended bits
    text (" G00 Y[23.5-(((#100-1)*1.500)+1.810)]\n") --go to tool # to pickup
    text (" G00 Z-3.000\n")
    text (" G00 Z-3.812 F10\n") --ready to lock pos.
    text (" G00 X2.5\n") --lock pos.
    text (" G00 Z-3 X4\n") --Pick it up and move clear off tool rack
    text (" G54\n") --Back to Fixture 1 this is the working fixture
    text (" #101=#100\n") --remember tool in chuck
    text (" T")
    number (tool, "0")
    text (" ;", toolname, "\n") --tell turbocnc what tool it has for offsets
    text (" ;\n")
    text (" ;--------------------------------\n")
    end
    The cordiances for the tool positions could be anywhere. Those numbers just reflect where I have the changer located now.
    Jerry
  6. #66
    Feb 2006
    213
    Exactly ,the deeper the better [stiffer] . I was thinking all the way top to bottom of he gantry walls ...
  7. #67
    Jun 2005
    142
    You should look at making money from your idea. Maybe a Dummies Guide to ATC or production of the product. Personally I would have no problem paying $100 for complete how to manual. As a newbie to CNC I would be the perfect proof reader.
    I am in final stages of my mill to do wood columns up to 24" by 12' and already have people asking me to build them a machine. see http://turningaround.org/4_axis_mill.htm . I realy don't want to get in the machine business and am looking for someone to work with as a consultant. What can I do to encourage you in your endevor? Be glad to add section on my web site , www.turningaround.org , if you want. Also a great way for me to learn more about your briliant idea.
  8. #68
    May 2005
    8
    etc...
    Jerry
    Jerry,
    thanks for the detail. This may be the project that finally forces me to learn how gcode works, so far I have been sheltering behind Sheetcam.
    Chris
  9. #69
    Oct 2003
    927
    I've been enjoying all this, but the videos aren't there anymore.
    Is there a new place(location where these can be viewed?
    I saw one that depicted the machine routing a sign and returning to change tools but can't find it anymore.
    Help anyone?
  10. #70
    Bloy2004, I have made a few video of my build, you can see them at http://web.mac.com/dacostad.
    I will be making another one next week of the finished machine.
    David
  11. #71
    Oct 2003
    927
    Hi David,
    Nice site! I've been watching you too as you progress.
    Will you be building the auto tool changer rack using the Hightech "rapid changer"? I'm wondering where those videos went...?
    I just ordered the changer system and am planning to set up a rack for tool holding/changing.
    John (bloy)
    P.S. here is my build from quite a while ago:
    http://www.cnczone.com/forums/showthread.php?t=5049
  12. #72
    I would like to have an ATC, but I am a little concerned about the safety of the HighTech current offering running at speeds well above it's design parameters (it's great on my Sherline).
    HighTech are working on an ATC solution for for higher speeds so I shall probably wait and see what they come out with.
  13. #73
    Oct 2003
    927
    yes, that is my concern too (the higher speeds), but Derek, at High tech has the heavy spring which will work for my router since it is variable speed and can function well in the 8Krpm to 11krpm range.
    One thing I have found is that changing tools manually is SOoooo inconvenient! :
    John (bloy)
  14. #74
    Apr 2005
    3634
    Quote Originally Posted by Bloy2004 View Post
    Is ther a new place(location where these can be viewed?
    Help anyone?
    I have all the videos that JLT posted on the toolchanger. I tried to post them all as 3 zip files (less than 8.58mb each) I got tired of waiting for the upload.
    PM me, I'll email them to you.
  15. #75
    Sep 2005
    35
    Atc
    I needed the room for other things.
    3 Videos back up for ATC. Testing Joe's ATC
    Spindle speed at 12000 rpm.
    Last video is with 1/4" spiral up cut end mill 1/4" deep at 45ipm one pass in cherry.
    Had to make 3 modifications to the the Rapid changer with 1/2" shaft from HTS for use with the router.
    http://video.google.com/videoplay?do...11940888627972
    http://video.google.com/videoplay?do...45240137833037
    http://video.google.com/videoplay?do...91859906584476
  16. #76
    Apr 2005
    3634
    Last video is with 1/4" spiral up cut end mill 1/4" deep at 45ipm one pass.
    http://home.comcast.net/~jlt313/Router/Mov00482.mpg
    http://home.comcast.net/~jlt313/Router/Mov00483.mpg
    http://home.comcast.net/~jlt313/Router/Mov00484.mpg
    Dead links?
  17. #77
    Aug 2004
    3215
    nice videos, and i also like the white splash quard you installed.
    joe
  18. #78
    Sep 2005
    35
    Here are some samples done with Joe's build.
    Corian inlay, cupboard doors, jewelry box.
    Attached Thumbnails Attached Thumbnails DSC00201.jpg   DSC00474.jpg   DSC00294.jpg   DSC00295.jpg
  19. #79
    Dec 2004
    1316
    Excellent results, the inlay sign is especially impressive.
    Jason
  20. #80
    May 2006
    954
    nice videos JLT, I like the "garage door" of sorts you've added to the tooling storage, what kind of mechanism did you have to create to get that to work?
Page 4 of 9 23456
  1. Joe's CNC Model 2006
    By joecnc2006 in forum Joes CNC Model 2006
    Last Post: 11-08-2022, 09:37 AM
  2. [AU] Joe's 2006 Model
    By nat.andrews in forum Joes CNC Model 2006
    Last Post: 11-11-2013, 11:50 AM
  3. Electronics for a Model 2006
    By joegtp in forum Joes CNC Model 2006
    Last Post: 08-31-2011, 04:43 PM
  4. New to Joe model 2006
    By Darroll in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 11:31 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
