Well remove motor today and found the bottom bearing turning inside the casing there is bearing greasing points on the motor but the bearing fitted were sealed with no way for the grease to get into them. My questions are do haas spindle motors have greasing points, this motor is 7.5hp general electric 1750rpm (would like confirmation that this is the correct spec motor for this machine) and how do you remove the pulley from the motor. thanks
