585,708 active members*
3,895 visitors online*
    Jul 2013
    84
    Homing MACH3 Turn (lathe)
    Hi Forum,
    this maybe a silly question but I have just setup my Lathe with Mach 3 for the first time, I have installed Z, X home limit switches, probe and E'stop which work as excepted. As I am only familiar with Mill operation, how does one in MAch3 tell the Z,X axis to go to home position and set Zero?
    Cant see this anywhere on the screens like mach mil?
    Aug 2017
    Re: Homing MACH3 Turn (lathe)
    Quote Originally Posted by itolond View Post
    Hi Forum,
    Should be on manual mode page. Home all..dont use that as it homes z then x. I dont think a machinist wrote mach 3. home z first then x if u want to prevent crashes. Well, i set up gang tooling so it is important for my set up.
    Sent from my SM-G900V using Tapatalk
  1. EMCO PC Turn 55 Homing
    By evengravy in forum EMCO Lathe
    Last Post: 06-02-2015, 11:21 AM
  2. need help bobcad lathe mach3 turn
    By hanover owing in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2012, 03:16 PM
  3. need help bobcad lathe mach3 turn threading
    By hanover owing in forum BobCad-Cam
    Last Post: 10-16-2012, 11:55 PM
  4. Homing lathe from software w/ Mach3?
    By CNC-Joe in forum Mach Lathe
    Last Post: 12-06-2008, 02:04 AM
