586,009 active members*
4,971 visitors online*
Results 1 to 6 of 6
    Jul 2006
    141
    Plasma to router table top?
    I have a PP plasma table with the HD gantry. It came with a router mount.
    We are looking to change out to a router for a long time job we bid on.
    The water tray slides out but what are people using for a table top so you have a flar surface to put spoil board onto? n
    Any ideas are welcome.
    Thanks in advance,
    Gary
    Aug 2009
    655
    Re: Plasma to router table top?
    Depends on what framework is left once you take off the water table. Commercial machines often have a phenolic grid but you can also do it in MDF (or layers of mdf) and then seal it with an epoxy sealer or similar (so it is air tight). You need it to be stable but you can get around the flat part (assuming it is close) when you mill the spoilboard down for use.
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Jul 2006
    141
    Here is a picture of the frame as we were building it.Attachment 297952
    As you can see not much there.
    Gary
    Aug 2014
    60
    thats a nice base you have there
    Aug 2009
    655
    Well easiest might be just more steel cross members, then mdf etc.
    Sent from my LG-D852 using Tapatalk
    Jul 2006
    141
    Thanks for the responses. I am going to add more supports and then plywood with a couple sheets of mdf. I will seal it up and see how it goes from there .
    Gary
  1. Plasma/Router Table
    By Mellding in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-25-2015, 08:19 PM
  2. looking at a used cnc plasma router table
    By ttm in forum Waterjet General Topics
    Last Post: 12-20-2011, 12:36 AM
  3. Plasma/Router Table
    By battenberg in forum Waterjet General Topics
    Last Post: 10-09-2011, 11:32 PM
  4. Router and plasma Table Design
    By littlegolub in forum DIY CNC Router Table Machines
    Last Post: 12-31-2009, 11:52 PM
  5. My first Router / Plasma Table Buildup...
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 01-05-2009, 05:20 AM
