585,722 active members*
3,956 visitors online*
Page 6 of 6 456
Results 101 to 118 of 118
  1. #101
    Nov 2008
    17
    Re: DYNACOM.EXE WANTED!!!!!
    Hi All,
    What version of Windows will run the Dynacom.exe file?
    Cheers
  2. #102
    Jan 2016
    4
    Cheers
    Quote Originally Posted by bolster55 View Post
    Hi All,
    Cheers
    Sorry, should have read the first post, 386 or 486.
    How do you tell if you have a 3000 or 3000H?
    Cheers
  3. #103
    The 3000H is the larger of the two. The 3000 is the bench top model. The stand is part of the 3000H.
    Looks like the 3000 weighs about 550 lbs whereas the 3000H is over 1000.
  4. #104
    Nov 2008
    17
    thanks for the reply, appreciated.
    Cheers
    Phil
  5. #105
    Mar 2010
    55
    Quote Originally Posted by Big Chips View Post
    any updates on the post?
    Sorry, I got distracted from it after the holidays, and since then my partner in the machine and I decided to convert it after all. If you still need a bobcad post then I suggest going to bobcad for it, as far as the fusion post, I think it's pretty good but fusion doesn't have any way to use our canned cycles. It seems to be more for g70-g73 canned cycles but ours more resemble pure facing and turning cycles. I wanted to help out with the bobcad end of things but I'm just too involved in other things right now.
  6. #106
    Mar 2010
    55
    Hi All,
    Cheers
    It's a msDOS executable. I know there are many pages and different topics from post processors to cables to serial ports but read through this thread. I was able to run the file in a DOS emulator called DOSbox complete with serial communication, I was able to write a messy qbasic program that is in my manual and compile that into exe and run on a modern PC in a cmd screen(don't recommend this, the program isn't well written) and I was also able to send the file with an open source free dnc program called edytornc. Predator editor should also be configurable for this. The 386/486 PC is what dynacom.exe is designed for and it would be an easy solution but there are several solutions in this thread that don't require you to buy another antiquated dusty machine. To send files to and from the Dyna machine.
  7. #107
    Nov 2008
    17
    Thanks danxj7x,
    I'll try and get my head around what you have written and setup communication with the 3000.
    I have it running with the original software and running very well, it would be better if I could use a screen instead of one line at a time.
    Roberto has helped me a lot by answering my questions, and, like I said, it is now running very well, and holding sizes extremely well.
    Regards
    Phil
  8. #108
    Nov 2008
    17
    Would it be possible to get a copy of the program for the DM3000?
    Regards
  9. #109
    Jun 2012
    514
    do you still need the program..if so i can help
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
  10. #110
    I see this thread is getting pretty dated but if anyone can share a working link to dynacom.exe that would be great. The dropbox link earlier in this post is no longer working.
  11. #111
    Nov 2008
    17
    Quote Originally Posted by danxj7x View Post
    i have a dyna myte 3000 lathe. and while i have another program that will send files to it i'd like the old dynacom.exe program. call it curiosity or whatever i would like to try this software and see what it has to offer. i am aware that it only runs on a 386 or 486 computer. i think i have a way around that, maybe two.
    if i get a copy of the program i'd offer up a package with it and either a dos emulator of virtual machine that could be run on an average modern computer with minimal setup.
    I have it running on Windows XP, with a lot of help from a friend that knows his way around computers.
  12. #112
    Quote Originally Posted by bradboudreaux View Post
    I could use it as well. Just picked up one after not having a dyna for 10 years.. Lost most everything.
  13. #113
    Apr 2021
    Hi please give me a copy od dynamyte.exe
    Is it possible using it for dynamyte 2800?
  14. #114
    Jul 2022
    6
    Please can I get a copy as well I just got 2 dm2800 I spent a bit of money on and broke the laptop that came with them now I can’t run these mills at all I have no manuals for them either so I’m really stuck.
  15. #115
    Jul 2022
    6
    Is there a way I could get a copy please
  16. #116
    Jul 2022
    6
    i have tons of parts if anyone is interested
  17. #117
    Jul 2022
    6
    anyone have any interest in any dm2800 parts i have drivers board steppers and like 5 controllers i might even part with one of the cnc i have it needs repair that is completely out of my scope of knowledge,
  18. #118
    Apr 2022
    14
    Is the dynacom software available somewhere?
    I am mostly interested in how to do a bulk dump on EM-3116, does the software offer the possibility?
Page 6 of 6 456
  1. WANTED
    By davesnd in forum Fagor Automation
    Last Post: 02-09-2011, 03:14 AM
  2. Help wanted
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 01-19-2011, 10:31 PM
  3. just wanted to say hey.
    By donmoran in forum Community Club House
    Last Post: 02-04-2010, 10:14 PM
  4. Just wanted you to know...
    By 307startup in forum Syil Products
    Last Post: 02-13-2007, 11:48 PM
