585,604 active members*
3,342 visitors online*
Results 1 to 7 of 7
    Nov 2015
    EZILATHE PROGRAM DOWNLOAD
    The download for Ezilathe we found does not have a install file.
    Can someone please help.
    Apr 2009
    125
    Re: EZILATHE PROGRAM DOWNLOAD
    Ezilathe does not need an install file, the directions are in the PDF.
    If you extract to C:\Ezilathe directory (create manually), and then copy the the files from the sample directory (imperial or metric) to the same directory, It should work.
    And yes it is checked out on Windows 10.
    Dec 2006
    3
    Hi Stu
    I have down loaded Ezilathe but cannot instalL (Windows 10)
    Have created folder in C drive named it Ezilathe unzipped and placed all files into folder.
    error comes up C:\Ezilathe\Materialm.txt dose not exist..Please copy to C:\Ezilathe
    Can you help
    Apr 2009
    125
    Ches
    2 possibilities, You have downloaded the update version (Missing data files to avoid overwriting your data), or downloaded the full version, but not moved the required files to C:\Ezilathe. If the former, you will need to Download the full version (Keep the update .exe file, and copy it back to C:\Ezilathe.
    Once the full version is downloaded, Copy all the datafiles from your choice (Metric or Imperial) directory directly into C:\Ezilathe. Both sample directories contain the Missing file + sample setup files to get you going, sample directories can be deleted at this point.
    Ezilathe should now run in your choosen units, ready to customize to suit your needs.
    If still no luck, then check the name of your directory it must be C:\Ezilathe.
    Hope this helps. Another thread is also in this Forum, it has many questions and answers in it, It is one of the two "Sticky" threads listed at the top of this forum.
    Dec 2006
    3
    Thank You
    Dec 2006
    3
    Hi Stu I am working with Ezilathe
    I have a CNC Lathe on which we turn wood.
    I draw the profile design in Qcad and save as DXF This tool path I want to cut in both directions .
    We have a Vee cutter which can cut up to depth of 24mm, this roughs out the shapeAttachment 481158
    I hope you can see the attachment if not please email me on [email protected] I will send you DXF file
    Also I need the G02 / G03 out put to be in X Z R how do we change this
    I would be most grateful if you can help
    Can the files be saved?
    Regards
    Ches
    Apr 2009
    125
    Ches
    All is possible. Radius mode arcs can be easily added as an option but are generally not as reliable as center format. I Assume you have a controller other than Mach 3 or 4.
    To add Radius format will require a program update, so not available immediately as other work in progress. Sent you an email.
  1. Ezilathe Cam Program - lathetdat.txt
    By datac in forum Uncategorised CAM Discussion
    Last Post: 11-20-2015, 04:08 AM
  2. Program up/download to PC on RS232 , 18i-T
    By microplus in forum Fanuc
    Last Post: 01-25-2013, 06:21 PM
  3. download cnc program problems
    By mikerichmond in forum Mastercam
    Last Post: 11-30-2011, 03:20 PM
  4. Fanuc 10M will not let program download.
    By rchunter94 in forum DNC Problems and Solutions
    Last Post: 05-12-2008, 10:59 PM
