I have a Hitachi WJ200 2.2kW VFD installed on a Bridgeport Series 1 Boss 5 Rigid Ram. All programming parameters are correct and is running great (analog control). However I still haven't wired in my bijour lube way pump (115v) on the mill as i've been manually priming the system. I read somewhere that most people run the lube pump only when the spindle is running to prevent over oiling.
I'm just a little confused on how it should be wired. I have searched through the manual but can't find anywhere a relay output option other than the AL section which seems is only a relay output signal in case of a fault or alarm. Is there an option on this VFD or do I have to rig up an isolated relay?
